Rpi gpio library not work with dietpi trixie
root@DietPi:~# journalctl -u node-red
Mar 20 17:09:51 DietPi systemd[1]: Started node-red.service - Node-RED (DietPi).
Mar 20 17:09:54 DietPi node-red[1150]: 20 Mar 17:09:54 - [info]
Mar 20 17:09:54 DietPi node-red[1150]: Welcome to Node-RED
Mar 20 17:09:54 DietPi node-red[1150]: ===================
Mar 20 17:09:54 DietPi node-red[1150]: 20 Mar 17:09:54 - [info] Node-RED version: v4.1.7
Mar 20 17:09:54 DietPi node-red[1150]: 20 Mar 17:09:54 - [info] Node.js  version: v25.8.1
Mar 20 17:09:54 DietPi node-red[1150]: 20 Mar 17:09:54 - [info] Linux 6.12.75+rpt-rpi-v8 arm64 LE
Mar 20 17:09:55 DietPi node-red[1150]: 20 Mar 17:09:55 - [info] Loading palette nodes
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Settings file  : /mnt/dietpi_userdata/node-red/settings.js
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Context store  : 'default' [module=memory]
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] User directory : /mnt/dietpi_userdata/node-red
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [warn] Projects disabled : editorTheme.projects.enabled=false
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Flows file     : /mnt/dietpi_userdata/node-red/flows.json
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Creating new flow file
Mar 20 17:09:58 DietPi node-red[1150]: ---------------------------------------------------------------------
Mar 20 17:09:58 DietPi node-red[1150]: Your flow credentials file is encrypted using a system-generated key.
Mar 20 17:09:58 DietPi node-red[1150]: If the system-generated key is lost for any reason, your credentials
Mar 20 17:09:58 DietPi node-red[1150]: file will not be recoverable, you will have to delete it and re-enter
Mar 20 17:09:58 DietPi node-red[1150]: your credentials.
Mar 20 17:09:58 DietPi node-red[1150]: You should set your own key using the 'credentialSecret' option in
Mar 20 17:09:58 DietPi node-red[1150]: your settings file. Node-RED will then re-encrypt your credentials
Mar 20 17:09:58 DietPi node-red[1150]: file using your chosen key the next time you deploy a change.
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Server now running at http://127.0.0.1:1880/
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [warn] Encrypted credentials not found
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Starting flows
Mar 20 17:09:58 DietPi node-red[1150]: 20 Mar 17:09:58 - [info] Started flows
Mar 20 17:13:01 DietPi node-red[1150]: 20 Mar 17:13:01 - [info] Installing module: node-red-node-pi-gpio, version: 2.0.7
Mar 20 17:13:08 DietPi node-red[1150]: 20 Mar 17:13:08 - [info] Installed module: node-red-node-pi-gpio
Mar 20 17:13:09 DietPi node-red[1150]: 2026-03-20 17:13:09 xCreatePipe: Can't set permissions (436) for //.lgd-nfy0, No such file or directory
Mar 20 17:13:09 DietPi node-red[1150]: Traceback (most recent call last):
Mar 20 17:13:09 DietPi node-red[1150]:   File "/mnt/dietpi_userdata/node-red/node_modules/node-red-node-pi-gpio/testgpio.py", line 3, in <module>
Mar 20 17:13:09 DietPi node-red[1150]:     import RPi.GPIO as GPIO
Mar 20 17:13:09 DietPi node-red[1150]:   File "/usr/lib/python3/dist-packages/RPi/GPIO/__init__.py", line 14, in <module>
Mar 20 17:13:09 DietPi node-red[1150]:     import lgpio
Mar 20 17:13:09 DietPi node-red[1150]:   File "/usr/lib/python3/dist-packages/lgpio.py", line 562, in <module>
Mar 20 17:13:09 DietPi node-red[1150]:     _notify_thread = _callback_thread()
Mar 20 17:13:09 DietPi node-red[1150]:   File "/usr/lib/python3/dist-packages/lgpio.py", line 504, in __init__
Mar 20 17:13:09 DietPi node-red[1150]:     self._file = open('.lgd-nfy{}'.format(self._notify), 'rb')
Mar 20 17:13:09 DietPi node-red[1150]:                  ~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Mar 20 17:13:09 DietPi node-red[1150]: FileNotFoundError: [Errno 2] No such file or directory: '.lgd-nfy-3'
Mar 20 17:13:09 DietPi node-red[1150]: 20 Mar 17:13:09 - [warn] rpi-gpio : Raspberry Pi specific node set inactive
Mar 20 17:13:09 DietPi node-red[1150]: 20 Mar 17:13:09 - [info] Added node types:
Mar 20 17:13:09 DietPi node-red[1150]: 20 Mar 17:13:09 - [info]  - node-red-node-pi-gpio:rpi-gpio in
Mar 20 17:13:09 DietPi node-red[1150]: 20 Mar 17:13:09 - [info]  - node-red-node-pi-gpio:rpi-gpio out
Mar 20 17:13:09 DietPi node-red[1150]: 20 Mar 17:13:09 - [info]  - node-red-node-pi-gpio:rpi-mouse
Mar 20 17:13:09 DietPi node-red[1150]: 20 Mar 17:13:09 - [info]  - node-red-node-pi-gpio:rpi-keyboard
Mar 20 17:16:27 DietPi node-red[1150]: 20 Mar 17:16:27 - [info] Installing module: node-red-piervin-sensor-wired, version: 0.1.0
Mar 20 17:16:33 DietPi node-red[1150]: 20 Mar 17:16:33 - [info] Installed module: node-red-piervin-sensor-wired
Mar 20 17:16:33 DietPi node-red[1150]: 20 Mar 17:16:33 - [info] Added node types:
Mar 20 17:16:33 DietPi node-red[1150]: 20 Mar 17:16:33 - [info]  - node-red-piervin-sensor-wired:sensor-ds18b20
Mar 20 17:16:53 DietPi node-red[1150]: 20 Mar 17:16:53 - [info] Stopping flows
Mar 20 17:16:53 DietPi node-red[1150]: 20 Mar 17:16:53 - [info] Stopped flows
Mar 20 17:16:53 DietPi node-red[1150]: 20 Mar 17:16:53 - [info] Updated flows
Mar 20 17:16:53 DietPi node-red[1150]: 20 Mar 17:16:53 - [info] Starting flows
Mar 20 17:16:53 DietPi node-red[1150]: 20 Mar 17:16:53 - [info] Started flows
Mar 20 17:17:11 DietPi node-red[1150]: 20 Mar 17:17:11 - [info] Stopping flows
Mar 20 17:17:11 DietPi node-red[1150]: 20 Mar 17:17:11 - [info] Stopped flows
Mar 20 17:17:11 DietPi node-red[1150]: 20 Mar 17:17:11 - [info] Updated flows
Mar 20 17:17:11 DietPi node-red[1150]: 20 Mar 17:17:11 - [info] Starting flows
Mar 20 17:17:11 DietPi node-red[1150]: 20 Mar 17:17:11 - [info] Started flows
root@DietPi:~#
