# Access problem to influxDB from node Red - different Server
**URL:** <https://discourse.nodered.org/t/access-problem-to-influxdb-from-node-red-different-server/50986>\
**Created:** [13 September 2021 21:19 UTC](https://discourse.nodered.org/t/access-problem-to-influxdb-from-node-red-different-server/50986 "2021-09-13T21:19:17Z")\
**Showing post:** 3
**Author:** ![kuema](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/kuema/32/6542_2.png) [@kuema](https://discourse.nodered.org/u/kuema)\
**Post date:** [14 September 2021 05:52 UTC](https://discourse.nodered.org/t/access-problem-to-influxdb-from-node-red-different-server/50986/3 "2021-09-14T05:52:40Z")
Did you - by any chance - upgrade to Influx 1.8.9? They have changed the way it starts, which broke several setups on slower systems or with many shards.
If that's the cause, there are some workarounds.
It has also be discussed on the forum: [Influxdb upgrade from v1.8.6 broken [FIX] v1.8.9 still broken](https://discourse.nodered.org/t/influxdb-upgrade-from-v1-8-6-broken-fix-v1-8-9-still-broken/50459)
and on Github: [https://github.com/influxdata/influxdb/issues/21967](https://github.com/influxdata/influxdb/issues/21967)
_[View the full topic](https://discourse.nodered.org/t/access-problem-to-influxdb-from-node-red-different-server/50986)._
