# Access variable within dashboard html template sent from function
**URL:** <https://discourse.nodered.org/t/access-variable-within-dashboard-html-template-sent-from-function/3725>\
**Created:** [5 October 2018 22:56 UTC](https://discourse.nodered.org/t/access-variable-within-dashboard-html-template-sent-from-function/3725 "2018-10-05T22:56:07Z")\
**Showing post:** 12
**Author:** ![shrickus](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/shrickus/32/517_2.png) [@shrickus](https://discourse.nodered.org/u/shrickus)\
**Post date:** [7 October 2018 00:28 UTC](https://discourse.nodered.org/t/access-variable-within-dashboard-html-template-sent-from-function/3725/12 "2018-10-07T00:28:00Z")
The "code" inside your `ui_template` node is sent to the dashboard for rendering, and since the node-red dashboard is an Angular v1.x app, you will be able to do a _lot_ of conditional rendering logic -- once you understand the [Ng directives](https://docs.angularjs.org/api/ng/directive) (that's Angular's magic elements/attributes/syntax) that are available...
For example, this html `<table>` element can be _conditionally rendered_ using the [ng-if](https://docs.angularjs.org/api/ng/directive/ngIf) test to see if there are any rows to display:
<table ng-if="msg.payload.length">
  <caption class="nr-dashboard-color">Notification Logs</caption>
  <tr>
    <th>S.No</th>
    <th>Notification No.</th>
    <th>Date and Time</th>
    <th>Status</th>
    <th>Action</th>
  </tr>
  <tr ng-repeat="row in msg.payload">
    <td>{{$index+1}}</td>
    <td>{{row.notification}}</td>
    <td>{{row.timestamp}}</td>
    <td>{{row.status}}</td>
    <td>
      <button ng-click="send({payload: row.notification});"
              ng-if="row.status!=='success'">Retry</button>
    </td>
  </tr>
</table>
Notice also the use of [ng-repeat](https://docs.angularjs.org/api/ng/directive/ngRepeat) to iterate over the payload data array, and the `ng-if` on the `<button>` element in the last column of the table. This way, the button only appears when that row has a status not equal to "success".
Finally, I use the [ng-click](https://docs.angularjs.org/api/ng/directive/ngClick) attribute on the button to get access to the Ng scope, which has the `send(...)` method defined for returning data to the node-red flow downstream from my `ui_template` node. In this example I am just sending the Notifaction No. back as the msg.payload -- but if you used `ng-click="send({ payload: row });"` it would return the entire row as an object.
Once you fall down this rabbit hole of client-side logic and control, trust me you will no longer want to spend a bunch of time trying to build up your html page programatically! I still use the core `template` node in mustache mode to do some simple variable substitution and array expansion, but Angular is much more powerful a solution for a use case like yours.
_[View the full topic](https://discourse.nodered.org/t/access-variable-within-dashboard-html-template-sent-from-function/3725)._
