# Adding a delay to injections
**URL:** <https://discourse.nodered.org/t/adding-a-delay-to-injections/48439>\
**Created:** [15 July 2021 07:01 UTC](https://discourse.nodered.org/t/adding-a-delay-to-injections/48439 "2021-07-15T07:01:10Z")\
**Showing post:** 9
**Post date:** [15 July 2021 08:46 UTC](https://discourse.nodered.org/t/adding-a-delay-to-injections/48439/9 "2021-07-15T08:46:50Z")
If you use multiple owfs nodes you shouldn't need to delay them, I advise against using the checkbox method in the node., it is safer to explicitly set the topic. Using the checkboxes a problem can arise if you open the node when one of the sensors is not available, it will be removed from the list of sensors to be fetched and will not automatically be re-included when the sensor recovers, unless you open the node again. I do it like this
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/1/5/151ff972a1a4eb30209a7a8151982ec2df7afe81.png)
In addition it is worth looking at aliasing in owserver. It is very easy to do that and then you can use addresses like `/bedroom_temp/temperature`rather than `26.E1CD92010000/temperature`.
_[View the full topic](https://discourse.nodered.org/t/adding-a-delay-to-injections/48439)._
