# Adding a Node-RED-Dashboard UI widget node makes everything else disappear
**URL:** https://discourse.nodered.org/t/adding-a-node-red-dashboard-ui-widget-node-makes-everything-else-disappear/62184
**Category:** General
**Tags:** node-red-dashboard, ui-widgets
**Created:** [4 May 2022 14:37 UTC](https://discourse.nodered.org/t/adding-a-node-red-dashboard-ui-widget-node-makes-everything-else-disappear/62184 "2022-05-04T14:37:51Z")
**Showing post:** 5
### Author: ![zenofmud](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/zenofmud/32/316_2.png) [@zenofmud](https://discourse.nodered.org/u/zenofmud)
#### Post date: [7 May 2022 18:52 UTC](https://discourse.nodered.org/t/adding-a-node-red-dashboard-ui-widget-node-makes-everything-else-disappear/62184/5 "2022-05-07T18:52:47Z")
Export your flow and attach it to a reply so someone can take a look at it
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/adding-a-node-red-dashboard-ui-widget-node-makes-everything-else-disappear/62184)._
