# Adding a "reduce" option to the Smooth node
**URL:** <https://discourse.nodered.org/t/adding-a-reduce-option-to-the-smooth-node/15180>\
**Created:** [5 September 2019 22:59 UTC](https://discourse.nodered.org/t/adding-a-reduce-option-to-the-smooth-node/15180 "2019-09-05T22:59:17Z")\
**Showing post:** 19
**Post date:** [6 September 2019 15:23 UTC](https://discourse.nodered.org/t/adding-a-reduce-option-to-the-smooth-node/15180/19 "2019-09-06T15:23:18Z")
> [@Colin](#):
> I am having difficulty thinking of an application where this feature would be useful. Can you suggest an example?
I currently use node-red-contrib-aggregator to achieve same effect in my pool temp monitor.
The pool sends readings every sec and I average the readings over 60 secs and then pass that on to rest of flow
I wouldn't want to just send a single value to represent the 60 readings as it may be an outlier - I use the average (actually the median value) instead
_[View the full topic](https://discourse.nodered.org/t/adding-a-reduce-option-to-the-smooth-node/15180)._
