Adding parameters of Api in HTTP Request Node
You are clearly new to node-red so I will include some extra info for you at the end but first, your issues...
You cannot evaluate strings in a field...
You can however use mustache syntax as is detailed in the built in help...
e.g...
http://192.168.1.9:1301/api/OmronTagData/OmronTagdata?TagID={{TagID}}&TagValue="{{TagValue}}"&dateTime={{dateTime}}
NOTE for this :backhand_index_pointing_up: to work, you would need to set msg.TagID, msg.TagValue and msg.dateTime in the msg that goes to the HTTP-Request node
your current flow will cause the HTTP-Request to be executed twice
A head start...
try importing this demo flow
[{"id":"1f20e2b49a5883ee","type":"inject","z":"b34765c4163ec6fe","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":100,"wires":[["7dd86e710129a958"]]},{"id":"6e0c72d1e28b47dc","type":"http request","z":"b34765c4163ec6fe","name":"","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:1301/api/OmronTagData/OmronTagdata?TagID={{TagID}}&TagValue=\"{{TagValue}}\"&dateTime={{dateTime}}","tls":"","persist":true,"proxy":"","authType":"bearer","senderr":false,"x":570,"y":100,"wires":[["5573231dec4d023d"]]},{"id":"5573231dec4d023d","type":"debug","z":"b34765c4163ec6fe","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":100,"wires":[]},{"id":"7dd86e710129a958","type":"change","z":"b34765c4163ec6fe","name":"","rules":[{"t":"set","p":"TagID","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"TagValue","pt":"msg","to":"77","tot":"num"},{"t":"set","p":"dateTime","pt":"msg","to":"$moment($now()).format(\"YYYY-MM-DD HH:mm\")\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":100,"wires":[["d1850a61c7fa64d9","6e0c72d1e28b47dc"]]},{"id":"d1850a61c7fa64d9","type":"debug","z":"b34765c4163ec6fe","name":"Check msg.TagID and msg.dateTime ","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":390,"y":160,"wires":[]}]
Canned test / help for those new to node-red...
I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
See this article in the cookbook for an example of how to join messages into one object.
There’s a great page in the docs (Working with messages : Node-RED) that will explain how to use the debug panel to find the right path to any data item.
BX00Cy7yHi
   code goes here
You can edit and correct your post by clicking the pencil :pencil: icon.
