# Adding parameters of Api in HTTP Request Node
**URL:** <https://discourse.nodered.org/t/adding-parameters-of-api-in-http-request-node/64205>\
**Category:** Hardware\
**Tags:** http-request, function-node\
**Created:** [21 June 2022 12:11 UTC](https://discourse.nodered.org/t/adding-parameters-of-api-in-http-request-node/64205 "2022-06-21T12:11:33Z")\
**Showing post:** 5
**Post date:** [21 June 2022 13:17 UTC](https://discourse.nodered.org/t/adding-parameters-of-api-in-http-request-node/64205/5 "2022-06-21T13:17:13Z")
You are clearly new to node-red so I will include some extra info for you at the end but first, your issues...
You cannot evaluate strings in a field...
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/3/a/3a57c32f6b2f40359dfc9bd87d34ef23d41d4824.png)
You can however use mustache syntax as is detailed in the built in help...
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/e/0/e03a43128108111cbf06800a1145757daead54c3.png)
e.g...
`http://192.168.1.9:1301/api/OmronTagData/OmronTagdata?TagID={{TagID}}&TagValue="{{TagValue}}"&dateTime={{dateTime}}`
NOTE for this 👆 to work, you would need to set `msg.TagID`, `msg.TagValue` and `msg.dateTime` in the `msg` that goes to the HTTP-Request node
your current flow will cause the HTTP-Request to be executed twice
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/d/4/d42d67d81495483691b45e784a89a1dd4cf972a3.png)
A head start...
try importing this demo flow
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/9/e/9e8c56dbf4fa5ee6f8b1f6ea0f7d6c67fc8bfd29.png)
[{"id":"1f20e2b49a5883ee","type":"inject","z":"b34765c4163ec6fe","name":"","props":[],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":100,"wires":[["7dd86e710129a958"]]},{"id":"6e0c72d1e28b47dc","type":"http request","z":"b34765c4163ec6fe","name":"","method":"POST","ret":"txt","paytoqs":"ignore","url":"http://192.168.1.9:1301/api/OmronTagData/OmronTagdata?TagID={{TagID}}&TagValue=\"{{TagValue}}\"&dateTime={{dateTime}}","tls":"","persist":true,"proxy":"","authType":"bearer","senderr":false,"x":570,"y":100,"wires":[["5573231dec4d023d"]]},{"id":"5573231dec4d023d","type":"debug","z":"b34765c4163ec6fe","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":750,"y":100,"wires":[]},{"id":"7dd86e710129a958","type":"change","z":"b34765c4163ec6fe","name":"","rules":[{"t":"set","p":"TagID","pt":"msg","to":"1","tot":"num"},{"t":"set","p":"TagValue","pt":"msg","to":"77","tot":"num"},{"t":"set","p":"dateTime","pt":"msg","to":"$moment($now()).format(\"YYYY-MM-DD HH:mm\")\t","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":320,"y":100,"wires":[["d1850a61c7fa64d9","6e0c72d1e28b47dc"]]},{"id":"d1850a61c7fa64d9","type":"debug","z":"b34765c4163ec6fe","name":"Check msg.TagID and msg.dateTime ","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":390,"y":160,"wires":[]}]
### Canned test / help for those new to node-red...
I recommend watching this playlist: [Node-RED Essentials](https://www.youtube.com/playlist?list=PLyNBB9VCLmo1hyO-4fIZ08gqFcXBkHy-6). The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
See [this article in the cookbook](https://cookbook.nodered.org/basic/join-streams) for an example of how to join messages into one object.
There’s a great page in the docs ([Working with messages : Node-RED](https://nodered.org/docs/user-guide/messages)) that will explain how to use the debug panel to find the right path to any data item.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/adding-parameters-of-api-in-http-request-node/64205)._
