# Adding payload into JSON object?
**URL:** <https://discourse.nodered.org/t/adding-payload-into-json-object/84668>\
**Created:** [17 January 2024 23:13 UTC](https://discourse.nodered.org/t/adding-payload-into-json-object/84668 "2024-01-17T23:13:06Z")\
**Author:** ![jbudd](https://avatars.discourse-cdn.com/v4/letter/j/5f8ce5/32.png) [@jbudd](https://discourse.nodered.org/u/jbudd)\
**Post date:** [18 January 2024 01:21 UTC](https://discourse.nodered.org/t/adding-payload-into-json-object/84668/4 "2024-01-18T01:21:56Z")
It's impossible to advise without seeing your flow.
Please also use a debug node set to display the whole msg object to share the data as it enters your flow.
Export your code using the hamburger menu and paste it here using the `</>`.
Copy the value that your debug node shows, _not a screen capture_. Again use the `</>` button to post it here.
There’s a great page in the docs ([Working with messages : Node-RED](https://nodered.org/docs/user-guide/messages)) that will explain how to use the debug panel to find the right path to any data item.
In order to make code readable and usable in the forum it is necessary to surround your code with three backticks (also known as a left quote or backquote `````)
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/adding-payload-into-json-object/84668)._
