Adding UI tab Dynamically
#1
Respected Concerned One,
Would there be a way to add ui tabs dynamically to the UI Dashboard?
Thanks in advance!
Best Regards,
Muhammad Rohan Ali Asmat
#2
No - not without a deploy.
#3
But, hiding/showing them dynamically is currently possible?
#4
Not sure about visibility on tabs, but you can switch tabs and change visibility of groups with the ui-control node.
No - tab visibility is not dynamic yet either. @shrickus has mentioned working on one - so at some point maybe.
Thanks for your reply!
Hi @shrickus,
May I ask if you are planning to release it soon?
#7
Any suggestions for supporting the dashboard for multiple users ?
#8
No - as the underlying Node-RED is not multiuser there is no sensible way to make the dashboard multiuser - at least not with security.
Oh ok, Thanks!
#10
If you are prepared to do more of the heavy lifting yourself, it would be possible to do with uibuilder.
#11
I'm hoping to finish the code enough to submit the PR this weekend. After that, I guess it could be another week before a new version is released, depending on Dave's schedule...
#12
Oh that would be great!
Would definitely like to try it out!
#13
Hi @shrickus
I would like to inquire, if the feature is ready for use!
Best Regards,
#14
No - still work in progress.
#15
oh ok! Thanks for the information!
In case you have a tentative date, it would be great to know!
#16
Hi @dceejay @shrickus,
May I ask if I can use this feature in development mode?
Best Regards,
#17
the work in progress is in this Pull Request - https://github.com/node-red/node-red-dashboard/pull/456
