# Alert / Toast on Worldmap (with timeout)
**URL:** <https://discourse.nodered.org/t/alert-toast-on-worldmap-with-timeout/100876>\
**Tags:** node-red-contrib-web-worldmap\
**Created:** [30 April 2026 12:21 UTC](https://discourse.nodered.org/t/alert-toast-on-worldmap-with-timeout/100876 "2026-04-30T12:21:15Z")\
**Showing post:** 16
**Author:** ![PizzaProgram](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/pizzaprogram/32/19431_2.png) [@PizzaProgram](https://discourse.nodered.org/u/PizzaProgram)\
**Post date:** [2 May 2026 12:46 UTC](https://discourse.nodered.org/t/alert-toast-on-worldmap-with-timeout/100876/16 "2026-05-02T12:46:25Z")
_... just in case someone else finds this topic, and also for myself to remember:_
### There is a full detailed topic, how to use UIBUILDER + WorldMap in an `<iframe>` together:
> [@Can I use the Worldmap nodes with UIBUILDER? (Yes)](https://discourse.nodered.org/t/can-i-use-the-worldmap-nodes-with-uibuilder-yes/87890):
> Question: Is it possible to use the [node-red-contrib-web-worldmap](https://flows.nodered.org/node/node-red-contrib-web-worldmap) nodes with UIBUILDER? Short answer: Yes, absolutely. If you are using a default Node-RED/UIBUILDER configuration, all you need to do is add the following line to your index.html file: \<iframe src="../worldmap/" class="worldmap"\>\</iframe\> If you have changed the map url away from the default, simply change the src attribute accordingly. Note the use of a relative URL here which saves you having to worry about the exact URL. If…
_[View the full topic](https://discourse.nodered.org/t/alert-toast-on-worldmap-with-timeout/100876)._
