# Alternate-node-red-installer
**URL:** <https://discourse.nodered.org/t/alternate-node-red-installer/81172>\
**Created:** [10 September 2023 08:35 UTC](https://discourse.nodered.org/t/alternate-node-red-installer/81172 "2023-09-10T08:35:34Z")\
**Showing post:** 9
**Post date:** [10 September 2023 10:02 UTC](https://discourse.nodered.org/t/alternate-node-red-installer/81172/9 "2023-09-10T10:02:57Z")
> [@Manuel\_o](#):
> So i can use bash \<(curl -sL [https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered](https://raw.githubusercontent.com/node-red/linux-installers/master/deb/update-nodejs-and-nodered)) to create node red as my main instance.
Not quite. This installs the core of node-red. You dont have any instances until you start node-red.
> [@Manuel\_o](#):
> than (in there) i can copy the settings.js, name it for example settings1881.js.
This is NOT necessary.
> [@Manuel\_o](#):
> Can you help me here a bit more please. I guess u changed uiPort: process.env.PORT || 1880, to uiPort: process.env.PORT || 1881 (for emxample).
No, dont do that.
See this: [Node red multiple instances - #7 by Steve-Mcl](https://discourse.nodered.org/t/node-red-multiple-instances/9787/7)
_[View the full topic](https://discourse.nodered.org/t/alternate-node-red-installer/81172)._
