# \[Announce\] node-red-contrib-homie-convention
**URL:** <https://discourse.nodered.org/t/announce-node-red-contrib-homie-convention/16329>\
**Created:** [4 October 2019 17:32 UTC](https://discourse.nodered.org/t/announce-node-red-contrib-homie-convention/16329 "2019-10-04T17:32:16Z")\
**Showing post:** 11
**Author:** ![Magnus\_P](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/magnus_p/32/15221_2.png) [@Magnus\_P](https://discourse.nodered.org/u/Magnus_P)\
**Post date:** [17 December 2019 07:44 UTC](https://discourse.nodered.org/t/announce-node-red-contrib-homie-convention/16329/11 "2019-12-17T07:44:28Z")
I trying to integrate the [Homey](https://homey.app/) to the Node-RED using the [MQTT Hub](https://homey.app/sv-se/app/nl.hdg.mqtt/MQTT-Hub/) app that sends Homie Convention (v3.0.1).
The problem I encounter is the Node and Property in the Node-Red Homie Node is not retained as selectable items in the drop down list. To find a new device I need to broadcast all devices again from the MQTT Hub application in Homey, then they show up, for a short while!
Additional I have another problem with the Input to the Node-Red Homie Node, the value is not updated (have checked by MQTT Explorer), is this related to above if there is no defined Node definition?
![Capture](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/2X/4/407de7d52af34c50f9b50e0ac3d2727974e84860.jpeg)
![node](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/2X/9/9aeced23aaa421b28b257f2b2b5f43588daedc82.jpeg)
_[View the full topic](https://discourse.nodered.org/t/announce-node-red-contrib-homie-convention/16329)._
