# \[Announce\] node-red-contrib-ui-contextmenu
**URL:** <https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211>\
**Created:** [2 October 2019 18:05 UTC](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211 "2019-10-02T18:05:53Z")\
**Showing post:** 22
**Post date:** [26 February 2020 09:49 UTC](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211/22 "2020-02-26T09:49:28Z")
Sorry to be the one to say (again!!) @BartButenaers but it's not working here.. 🙁
I've configured the node as per the readme, using a simple fixed menu, but it does not appear in the dashboard group.
Checking my browser console, I see the following;
 ![menu1](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/5/e/5ee0d31031897dcd81a637d167f4481d82221c12.jpeg)
If I try and load `https://nodered.digitalnut.co.uk:8443/ui/ui_context_menu/contextmenu.js?_=1582707759368` in a browser (as per the 401 error above) I get a prompt for auth. If I enter my user/password, then the [contents of this file](https://github.com/bartbutenaers/node-red-contrib-ui-contextmenu/blob/master/lib/contextmenu.js) is then displayed.
The same applies with `https://nodered.digitalnut.co.uk:8443/ui/ui_context_menu/contextmenu.css`, again I'm prompted for auth.
I'm assuming that this is because I've password protected the Node-RED editor, admin API & the node-defined HTTP endpoints using `adminAuth` & `httpNodeAuth` (remember we had similar issues with node-red-contrib-xterm).
_[View the full topic](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211)._
