# \[Announce\] node-red-contrib-ui-contextmenu
**URL:** <https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211>\
**Created:** [2 October 2019 18:05 UTC](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211 "2019-10-02T18:05:53Z")\
**Showing post:** 55
**Post date:** [2 November 2021 11:04 UTC](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211/55 "2021-11-02T11:04:45Z")
Hi, no problem to be late.
What you need is one or more callbacks injected into ui-table via `msg.ui_control` i.e.
    "customHeight": 18,
    "tabulator": {
        "columns": [
                "field": "expand",
                "headerTooltip": "click to expand more details",
                "headerContext": "function(e,column){ this.send({ui_control:{callback:'headerContext'},position:{\"x\":e.x,\"y\":e.y},payload:column.getFieled()}); e.preventDefault(); }"
The function in a more readable format you can define for every column, cell or row ... (this one only reacts on context (right) clicks on the header
var headerContext= function (e, column) {
    this.send(
        {ui_control: { callback: 'headerContext' },
         position: { "x":e.x,"y":e.y},
         payload:column.getField()
    e.preventDefault();
there is a `cellContext` or `rowContext` too with slightly different parameters
> **[Tabulator - Interactive JavaScript Tables](http://tabulator.info/docs/4.7/callbacks)**
> Create interactive data tables in seconds with Tabulator. A lightweight, fully featured JavaScript table generation library.
_[View the full topic](https://discourse.nodered.org/t/announce-node-red-contrib-ui-contextmenu/16211)._
