I really recommend the Kaldi profile which i also use personally as it’s really fast.
I installed it and it seems to work very well. I guess its not possible to recognize speech which is not defined in the sentences.ini ?
I actually implemented a little trick in our stt node that wouldn’t work in transcribe-stream.
As soon as I have a microphone connected to my raspi I will try that out. Btw: Is that the (recommended) way it works with a wake word then ?
I hope this answers all of your questions for now.
You did ! Much thanx again for your patience !
By the way if you find the time to take a few screenshots and explain how you set up tasker to record audio and send it to nodered feel free to send it to me or do a pull request on our documentation as this is would be a very valuable addition to the possible set ups documentation as i unfortunately dont have any android devices.
I will write a documentation which you can use the way you like. Actually the tasker app will record a fixed time. This is not optimal. I would like to figure out if a silent detection is possible or a better solution like holding a button for the recording time...or so
