Excited to use this node you guys created. I am having a problem getting it going however. I followed the instructions and the result of the training process provides the following error:
Command failed: voice2json --profile /home/pi/Public/en-us_kaldi-zamia-2.0 train-profilengramcount: /lib/arm-linux-gnueabihf/libm.so.6: version GLIBC_2.27' not found (required by ngramcount)ngramcount: /lib/arm-linux-gnueabihf/libm.so.6: version GLIBC_2.27' not found (required by /usr/lib/voice2json/lib/libngram.so.134)[13296] Failed to execute script __main__Traceback (most recent call last): File "__main__.py", line 6, in <module> File "asyncio/runners.py", line 43, in run File "asyncio/base_events.py", line 587, in run_until_complete File "voice2json/__main__.py", line 73, in main File "voice2json/__main__.py", line 733, in train File "voice2json/core.py", line 65, in train_profile File "voice2json/train.py", line 299, in train_profile File "rhasspyasr_kaldi/train.py", line 92, in train File "rhasspynlu/arpa_lm.py", line 55, in graph_to_arpa File "rhasspynlu/arpa_lm.py", line 70, in fst_to_arpa File "rhasspynlu/arpa_lm.py", line 345, in run_task File "s...
$PATH includes home/pi/Public, which is where the en-us_kaldi-zamia-2.0 files are located. Any suggestions?
