# \[ANNOUNCE\] OpenAi Node-RED Plugin
**URL:** <https://discourse.nodered.org/t/announce-openai-node-red-plugin/80007>\
**Created:** [22 July 2023 09:58 UTC](https://discourse.nodered.org/t/announce-openai-node-red-plugin/80007 "2023-07-22T09:58:19Z")\
**Showing post:** 13
**Author:** ![MaxBaines](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/maxbaines/32/81476_2.png) [@MaxBaines](https://discourse.nodered.org/u/MaxBaines)\
**Post date:** [26 July 2023 11:53 UTC](https://discourse.nodered.org/t/announce-openai-node-red-plugin/80007/13 "2023-07-26T11:53:15Z")
Another item not mentioned yet by me, which may be of some concern or interest is privacy of your data. There is often some confusion in most communities and indeed professions at the minute about how OpenAi treat you data, I needed to look into this as part of my job, hopefully the following helps -
The plugin, sends and receives responses from the OpenAI API. When using the OpenAI API's your data is not retained or used to train models, for details see:
> **[API data privacy](https://openai.com/api-data-privacy)**
> At OpenAI, protecting user data is fundamental to our mission. We do not train our models on inputs and outputs through our API.
Note, this is a different policy to ChatGPT itself, when using ChatGPT your data is retained and used to train models.
To be clear this plugin does not use ChatGPT instead it uses the OpenAI API.
_[View the full topic](https://discourse.nodered.org/t/announce-openai-node-red-plugin/80007)._
