# Apexcharts how to add js scripts
**URL:** <https://discourse.nodered.org/t/apexcharts-how-to-add-js-scripts/49825>\
**Created:** [17 August 2021 08:40 UTC](https://discourse.nodered.org/t/apexcharts-how-to-add-js-scripts/49825 "2021-08-17T08:40:13Z")\
**Post date:** [17 August 2021 10:39 UTC](https://discourse.nodered.org/t/apexcharts-how-to-add-js-scripts/49825/2 "2021-08-17T10:39:04Z")
> [@nerevar](#):
> There is virtualy no info whatsoever how to implement other chart into existing dashboard
That isn't what Dashboard is for. It is aimed at people with no html/js experience and enables them to have a UI simply by providing nodes in Node-RED flows.
If you want a custom UI, you may wish to try uibuilder.
> [@nerevar](#):
> Please can anybody help me with this one
It is helpful to share the ui\_template code directly not just the flow file (since that takes time to paste into NR and tidy up afterwards).
If I am reading the raw flow correctly, I think you have assumed that the ui\_template needs to have a full HMTL file. But the ui\_template node is just a snippet that is inserted into the Dashboard page.
> [@nerevar](#):
> a possible solution to import scripts from local storage (C:\apexcharts-bundle\dist)
All you need to do is put the script file into the folder you have declared in settings.js as the static resources folder.
_[View the full topic](https://discourse.nodered.org/t/apexcharts-how-to-add-js-scripts/49825)._
