# Archiving and synchronization of data along with time stamp with MQTT broker after failure of internet connection in IOT gateway
**URL:** <https://discourse.nodered.org/t/archiving-and-synchronization-of-data-along-with-time-stamp-with-mqtt-broker-after-failure-of-internet-connection-in-iot-gateway/12770>\
**Created:** [1 July 2019 06:22 UTC](https://discourse.nodered.org/t/archiving-and-synchronization-of-data-along-with-time-stamp-with-mqtt-broker-after-failure-of-internet-connection-in-iot-gateway/12770 "2019-07-01T06:22:43Z")\
**Showing post:** 3
**Post date:** [1 July 2019 07:22 UTC](https://discourse.nodered.org/t/archiving-and-synchronization-of-data-along-with-time-stamp-with-mqtt-broker-after-failure-of-internet-connection-in-iot-gateway/12770/3 "2019-07-01T07:22:02Z")
A good first step is always to search this forum to see if the question has come up before.
> [@MQTT - Storing data when disconnected](https://discourse.nodered.org/t/mqtt-storing-data-when-disconnected/9306/9):
> So the Node-RED mqtt node has made qos 1 and 2 redundant by having a connection check around publish. The underlying mqtt client lib already manages messages correctly based on qos. In fact the mqtt client can be configured with a storage policy. The default policy is es6-map. If Node-RED is running in a constrained environment where qos\>0 can not be supported. Then I would expect qos to be set to 0 in that environment.
Which while not giving an answer, will give you lots of things to think about...
_[View the full topic](https://discourse.nodered.org/t/archiving-and-synchronization-of-data-along-with-time-stamp-with-mqtt-broker-after-failure-of-internet-connection-in-iot-gateway/12770)._
