# Assistance required - Dashboard Dynamic button that can Appear/Disapear on true or false variable
**URL:** <https://discourse.nodered.org/t/assistance-required-dashboard-dynamic-button-that-can-appear-disapear-on-true-or-false-variable/67608>\
**Tags:** node-red-dashboard\
**Created:** [12 September 2022 11:43 UTC](https://discourse.nodered.org/t/assistance-required-dashboard-dynamic-button-that-can-appear-disapear-on-true-or-false-variable/67608 "2022-09-12T11:43:50Z")\
**Post date:** [12 September 2022 12:00 UTC](https://discourse.nodered.org/t/assistance-required-dashboard-dynamic-button-that-can-appear-disapear-on-true-or-false-variable/67608/2 "2022-09-12T12:00:24Z")
You can put the button in its own ui group then use ui-control node to show/hide disable/enable the group, all is explained in the node info help text.
Or
You can use ui-template node to create a button and use ng-if to show or hide on true/false. I recently posted an example in this thread. [Add text to ui template based on javascrip function - #6 by E1cid](https://discourse.nodered.org/t/add-text-to-ui-template-based-on-javascrip-function/67526/6)
_[View the full topic](https://discourse.nodered.org/t/assistance-required-dashboard-dynamic-button-that-can-appear-disapear-on-true-or-false-variable/67608)._
