# (Async) multiple input for nodes\*
**URL:** <https://discourse.nodered.org/t/async-multiple-input-for-nodes/101476>\
**Tags:** function-node, subflow, flows\
**Created:** [15 July 2026 01:09 UTC](https://discourse.nodered.org/t/async-multiple-input-for-nodes/101476 "2026-07-15T01:09:24Z")\
**Showing post:** 6
**Author:** ![Robert0](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/robert0/32/108008_2.png) [@Robert0](https://discourse.nodered.org/u/Robert0)\
**Post date:** [15 July 2026 08:53 UTC](https://discourse.nodered.org/t/async-multiple-input-for-nodes/101476/6 "2026-07-15T08:53:42Z")
Hi,
Thank you for that article. I was aware of how exactly Node-RED works and why they have selected this approach. I am also familiar with many other frameworks, such as Vykon Niagara and Siemens AF. I wanted to avoid any discussions as enough has been said throughout this forum.
It is my mistake for not being clear on what side I am and what type of plugin I was making.
Apologies
EDIT: Some posts I tried to find back:
> [@Subflow multiple inputs support](https://discourse.nodered.org/t/subflow-multiple-inputs-support/90805):
> I has viewed the forum [why-dont-node-red-nodes-allow-multiple-inputs](https://discourse.nodered.org/t/why-dont-node-red-nodes-allow-multiple-inputs/10973). And I have some different perspectives about multiple inputs in subflow node. In an example like the one below,multiple inputs will be more convenient.
> [@Multiple Inputs and Multiple Outputs](https://discourse.nodered.org/t/multiple-inputs-and-multiple-outputs/2912):
> Good morning everyone, I am using Node-Red with OPCUA to connect to a controller and display the values in their own gauge to the dashboard. I was wondering if there may be a better way to do this. My thinking is that it is not necessary to create an OPC UA Client node for each OPCUA Node that I want to read. I also wonder if this is creating a separate connection for each node that I want to read. Can someone please advise if my thinking is correct and if there would be some way to use only…
> [@Reading multiple items with node-red-contrib-opcua](https://discourse.nodered.org/t/reading-multiple-items-with-node-red-contrib-opcua/54259):
> I am including several production lines into my data-gathering program. They use OPC-UA to offer me the information. Single parameter readings are not a problem anymore: I send the nodeid for the parameter I want to read, and I get a message with that single parameter. This is fine. However, we have 3 production lines (times 3) and we're talking about reading hundreds of parameters. Having a full message for each one will be an incredible overhead, so I want to use the read multiple function. T…
_[View the full topic](https://discourse.nodered.org/t/async-multiple-input-for-nodes/101476)._
