BASH help with messages
Well, I may need some help.
Because I tried and it doesn't work.
A reply from github when I asked about what I was doing:
Old issue, but as far as I can understand from the code, wild cards are not supported in the Move node
So it kind of stops me doing what I want.
This is what I have/had:
[{"id":"5e6fb122.e2971","type":"change","z":"9b7e7466.a4b698","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"directory","tot":"msg"},{"t":"set","p":"path","pt":"msg","to":"log_paths","tot":"global"}],"action":"","property":"","from":"","to":"","reg":false,"x":420,"y":4280,"wires":[["5057e468.77a39c","7cf09090.6ab6a"]]},{"id":"5057e468.77a39c","type":"template","z":"9b7e7466.a4b698","name":"add to paths","field":"payload","fieldType":"msg","format":"handlebars","syntax":"mustache","template":"{{{path}}}reboot","output":"str","x":610,"y":4280,"wires":[["f7522d25.e854","a9329fb3.3ef568"]]},{"id":"7cf09090.6ab6a","type":"debug","z":"9b7e7466.a4b698","name":"RAW","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":450,"y":4240,"wires":[]},{"id":"faaaeaaa.74bb4","type":"moment","z":"9b7e7466.a4b698","name":"","topic":"","input":"","inputType":"msg","inTz":"Australia/Sydney","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-ww","locale":"en_AU","output":"","outputType":"msg","outTz":"Australia/Sydney","x":210,"y":4280,"wires":[["5e6fb122.e2971"]]},{"id":"f7522d25.e854","type":"function","z":"9b7e7466.a4b698","name":"Build stuff","func":"//msg.SourcePath = msg.path + \"reboot\";\nmsg.SourcePath = msg.payload;\nmsg.Destination = msg.payload + \"/\" + msg.directory;\nreturn msg;","outputs":1,"noerr":0,"x":180,"y":4320,"wires":[["445b099e.218268"]]},{"id":"a9329fb3.3ef568","type":"debug","z":"9b7e7466.a4b698","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":770,"y":4280,"wires":[]},{"id":"29def37a.d3db04","type":"inject","z":"9b7e7466.a4b698","name":"Weekly","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"50 23 * * 0","once":false,"onceDelay":0.1,"x":170,"y":4240,"wires":[["faaaeaaa.74bb4"]]},{"id":"445b099e.218268","type":"fs-ops-dir","z":"9b7e7466.a4b698","name":"","path":"SourcePath","pathType":"msg","filter":"Rebooted at*","filterType":"str","dir":"payload","dirType":"msg","x":400,"y":4320,"wires":[["a11895ed.469918"]]},{"id":"a11895ed.469918","type":"switch","z":"9b7e7466.a4b698","name":"","property":"payload[0]","propertyType":"msg","rules":[{"t":"nnull"}],"checkall":"true","repair":false,"outputs":1,"x":590,"y":4320,"wires":[["7680a022.40ee48","c4bbba2d.83793","a9d5ed52.438db8"]]},{"id":"c4bbba2d.83793","type":"fs-ops-mkdir","z":"9b7e7466.a4b698","name":"","path":"SourcePath","pathType":"msg","dirname":"directory","dirnameType":"msg","mode":"777","fullpath":"directory","fullpathType":"msg","x":200,"y":4360,"wires":[["7c410aa0.950d84"]]},{"id":"a9d5ed52.438db8","type":"delay","z":"9b7e7466.a4b698","name":"Delay","pauseType":"delay","timeout":"2","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":170,"y":4400,"wires":[["c99cae1e.a65dd8"]]},{"id":"7c410aa0.950d84","type":"debug","z":"9b7e7466.a4b698","name":"1","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":390,"y":4360,"wires":[]},{"id":"c99cae1e.a65dd8","type":"split","z":"9b7e7466.a4b698","name":"","splt":"\\n","spltType":"str","arraySplt":1,"arraySpltType":"len","stream":false,"addname":"","x":390,"y":4400,"wires":[["9864152e.47845","1b431cb4.6881db"]]},{"id":"9864152e.47845","type":"debug","z":"9b7e7466.a4b698","name":"1d","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":590,"y":4440,"wires":[]},{"id":"1b431cb4.6881db","type":"fs-ops-move","z":"9b7e7466.a4b698","name":"","sourcePath":"SourcePath","sourcePathType":"msg","sourceFilename":"payload","sourceFilenameType":"msg","destPath":"Destination","destPathType":"msg","destFilename":"payload","destFilenameType":"msg","link":false,"x":600,"y":4400,"wires":[["5feaab5c.72b54c"]]},{"id":"5feaab5c.72b54c","type":"debug","z":"9b7e7466.a4b698","name":"2","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":770,"y":4400,"wires":[]}]
Given the global and flow things are set - of course.
(Typically)
I tried it again and it works.
