# Best way to check the connected state of an MQTT node before publishing?
**URL:** <https://discourse.nodered.org/t/best-way-to-check-the-connected-state-of-an-mqtt-node-before-publishing/7955>\
**Created:** [14 February 2019 09:34 UTC](https://discourse.nodered.org/t/best-way-to-check-the-connected-state-of-an-mqtt-node-before-publishing/7955 "2019-02-14T09:34:20Z")\
**Showing post:** 6
**Post date:** [14 February 2019 14:19 UTC](https://discourse.nodered.org/t/best-way-to-check-the-connected-state-of-an-mqtt-node-before-publishing/7955/6 "2019-02-14T14:19:33Z")
You can use a Status node to tell you the current state of the connection.
_[View the full topic](https://discourse.nodered.org/t/best-way-to-check-the-connected-state-of-an-mqtt-node-before-publishing/7955)._
