Bitwise XOR on ASCII string
A few ideas
Are you sure your input is a string and not a buffer object (set of bytes)?
If your sure its a string then I'd change it to a buffer
var check_sum_string = Buffer.from( msg.payload, 'utf8' )
I'd use
var check_sum = 0
to initialise it as numeric
check_sum = check_sum_string[i] ^ check_sum_string[i+1];
looks a bit wrong on the logic front :slight_smile:
I'd try something like
check_sum = check_sum ^ check_sum_string[i]
