By looking at your flow I see you are using FlowFuse Dashboard AKA Dashboard 2.0 but in your original post you stated:
I use Dashboard 1
I guess you have updated? You should tag this post with dashboard-2 to remove confusion
Next, your CSS is:
.round button {
border-radius: 50%;
background-image: url("/redbutton.png");
background-size: cover;
max-height: calc( 2 * var(--widget-row-height));
min-height: calc( 2 *var(--widget-row-height));
max-width: calc( 2 *var(--widget-row-height));
min-width: calc( 2 *var(--widget-row-height));
- How are you serving
"/redbutton.png"? - Did you edit your settings.js to serve static content?
- Have you tested the URL in your browser - to check that the image is actually being served?
- e.g. if your Node-RED is at
http://localhost:1880then try accessinghttp://localhost:1880/redbutton.png- do you see the image?
Alternatively, you could serve the image using http-in > read file > http-response nodes to avoid setting up http static. There is an example in the dashboard-2.0 ui-template docs see this recent post: Display image in buffer in template node - #4 by Steve-Mcl
