# Buttons on inject and debug node not active
**URL:** <https://discourse.nodered.org/t/buttons-on-inject-and-debug-node-not-active/92083>\
**Tags:** home-assistant\
**Created:** [30 September 2024 20:45 UTC](https://discourse.nodered.org/t/buttons-on-inject-and-debug-node-not-active/92083 "2024-09-30T20:45:10Z")\
**Post date:** [2 October 2024 06:12 UTC](https://discourse.nodered.org/t/buttons-on-inject-and-debug-node-not-active/92083/4 "2024-10-02T06:12:40Z")
> [@bkr1969](#):
> There are all kinds of error messages in the dev console
Show us please
> [@bkr1969](#):
> My flows run, but I cannot test without inject nodes.
This suggests a problem with websockets as I stated in your own thread:
> [@Inject Nodes Not Clickable](https://discourse.nodered.org/t/inject-nodes-not-clickable/92104/6):
> I am reliably informed this is not a new thing for HA users of node-red. Something to do with websockets
This appears to be related to home assistant and your installation. You could try searching the home assistants own forum?
In fact a quick Google search - first hit - [Nodered corrupted, can not use inject node - Node-RED - Home Assistant Community](https://community.home-assistant.io/t/nodered-corrupted-can-not-use-inject-node/509809)
- Check for & remove any duplicate home assistant config nodes
- Access node-red directly using [`ha-ip-address]:1880`
_[View the full topic](https://discourse.nodered.org/t/buttons-on-inject-and-debug-node-not-active/92083)._
