Buttons, pressing and when to send messages
good word... not used nearly often enough... :slight_smile:
Like that idea, but why a logic gate, you could use the msg.enabled to lock down the buttons.
You could use ui-control, so when you land on dashboard page it auto enables for a time period then disables. After which you can press an enable button to re-enable the page for a time out period. That way when you want the dashboard page, when you first land, all works.
e.g.
[{"id":"7f576a8f.e2aa9c","type":"ui_ui_control","z":"bf9e1e33.030598","name":"","events":"all","x":110,"y":760,"wires":[["86c4adf5.333f7"]]},{"id":"86c4adf5.333f7","type":"switch","z":"bf9e1e33.030598","name":"","property":"name","propertyType":"msg","rules":[{"t":"eq","v":"tab2","vt":"str"}],"checkall":"true","repair":false,"outputs":1,"x":280,"y":760,"wires":[["1718b24a.75a436"]]},{"id":"1718b24a.75a436","type":"ui_button","z":"bf9e1e33.030598","name":"","group":"329fde9ce45e135e","order":1,"width":"3","height":"1","passthru":true,"label":"enable","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"1","payloadType":"str","topic":"topic","topicType":"msg","x":120,"y":800,"wires":[["82520686.e37c6"]]},{"id":"82520686.e37c6","type":"trigger","z":"bf9e1e33.030598","name":"","op1":"true","op2":"false","op1type":"bool","op2type":"bool","duration":"10","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":160,"y":840,"wires":[["5267c4be.ea59d4"]]},{"id":"5267c4be.ea59d4","type":"change","z":"bf9e1e33.030598","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"enabled","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":150,"y":900,"wires":[["efa82ca.88da75","7e88566f.6168f8","fa3e9134.b9cc3","6d8fe703.5d9868"]]},{"id":"efa82ca.88da75","type":"ui_switch","z":"bf9e1e33.030598","name":"","label":"switch3","tooltip":"","group":"329fde9ce45e135e","order":4,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":430,"y":960,"wires":[["315edfa6.413308"]]},{"id":"7e88566f.6168f8","type":"ui_switch","z":"bf9e1e33.030598","name":"","label":"switch4","tooltip":"","group":"329fde9ce45e135e","order":5,"width":0,"height":0,"passthru":false,"decouple":"false","topic":"topic","topicType":"msg","style":"","onvalue":"true","onvalueType":"bool","onicon":"","oncolor":"","offvalue":"false","offvalueType":"bool","officon":"","offcolor":"","animate":false,"className":"","x":450,"y":1020,"wires":[["315edfa6.413308"]]},{"id":"fa3e9134.b9cc3","type":"ui_button","z":"bf9e1e33.030598","name":"","group":"329fde9ce45e135e","order":2,"width":0,"height":0,"passthru":false,"label":"button1","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"1","payloadType":"str","topic":"topic","topicType":"msg","x":400,"y":900,"wires":[["315edfa6.413308"]]},{"id":"6d8fe703.5d9868","type":"ui_button","z":"bf9e1e33.030598","name":"","group":"329fde9ce45e135e","order":3,"width":0,"height":0,"passthru":false,"label":"button2","tooltip":"","color":"","bgcolor":"","className":"","icon":"","payload":"2","payloadType":"str","topic":"topic","topicType":"msg","x":400,"y":860,"wires":[["315edfa6.413308"]]},{"id":"315edfa6.413308","type":"debug","z":"bf9e1e33.030598","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":610,"y":940,"wires":[]},{"id":"329fde9ce45e135e","type":"ui_group","name":"Group 1","tab":"8d72c2dc8ebb3926","order":1,"disp":true,"width":6},{"id":"8d72c2dc8ebb3926","type":"ui_tab","z":"c791cbc0.84f648","name":"tab2","icon":"dashboard"}]
Except in Prauge.... :wink:
This is an example of me doing the Enable button example
Screenshot from 2022-02-23 06-37-16
Ok, I haven't gone to the extend of disabling the buttons. But while they are red, you can't press them.
And here are some examples where I have used the disable function also.
If they are not turned on (or plugged in) the button is blocked.
ARLEC-1 is plugged in and I can control it. Just now it is off.
But that this is slightly different to the original question.
So: I have tried different things.
I would like to invest time in getting ONE of these nice so I can set it free to the world.
The second part (and I have not thought of a third, but I'll get back to that)
Most of this has also gone to the second option.
You have to press the button twice to send A SPECIFIC message.
Originally I was wanting the message to toggle. ON/OFF - if you will.
This is because I have needs where sending a single message doesn't quite cut the mustard. An alternating message is what was needed.
The third idea which recently came to mind is not so much a guard button/feature, but a You have to hold the button pressed for a certain time.
This is common IRL so you can't just brush past and bump a button.
You have to deliberately PRESS (and hold) the button for a few seconds to kind of confirm you want it to be pressed.
That is easy to get done with a couple of resistors and a capacitor.
(But anyway)
So why did it take 24 posts before we got to actually talking about how to do what I was wanting to do originally?
This is another flow which is a Press LONG to activate button.
Bit of CSS.
Edit the trigger node to set how long the button has to be pressed.
[{"id":"6f98195d1579e571","type":"ui_template","z":"1283f6a97005461c","group":"574552148f91ef06","name":"Press button","order":1,"width":1,"height":1,"format":"<div id=\"VolUp2\">\n   <md-button class=\"md-button TV-AUDIO\" aria-label=\"VolUp\">\n      <span class=\"fa fa-hand-pointer-o fa-2x\"> </span>\n   </md-button>\n</div>\n\n<script>\n\n(function($scope) {\n    \n$('#VolUp2').on('touchstart mousedown', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"topic\":\"button\",\"payload\": \"Down\"});\n});\n\n$('#VolUp2').on('touchend mouseup', function(e) {\n    e.preventDefault(); //prevent default behavior\n    $scope.send({\"topic\":\"button\",\"payload\": \"Up\"});\n});\n    \n})(scope);\n</script>","storeOutMessages":true,"fwdInMessages":false,"resendOnRefresh":true,"templateScope":"local","x":910,"y":510,"wires":[["32d1e63e2ec71d3a"]],"info":"<span class=\"fa-stack fa-lg\">\n  <i class=\"fa fa-camera fa-stack-1x\"></i>\n  <i class=\"fa fa-ban fa-stack-2x text-danger\"></i>\n</span>\nfa-ban on fa-camera\n"},{"id":"32d1e63e2ec71d3a","type":"switch","z":"1283f6a97005461c","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"Down","vt":"str"},{"t":"eq","v":"Up","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1070,"y":510,"wires":[["26cb0f27462f9cd6"],["81e962f5e7a852ce"]]},{"id":"26cb0f27462f9cd6","type":"trigger","z":"1283f6a97005461c","name":"","op1":"","op2":"ON","op1type":"nul","op2type":"str","duration":"2","extend":false,"overrideDelay":false,"units":"s","reset":"","bytopic":"all","topic":"topic","outputs":1,"x":1230,"y":490,"wires":[["a77168c5af53b7ed","ed397177cda95b5a"]]},{"id":"81e962f5e7a852ce","type":"change","z":"1283f6a97005461c","name":"Reset","rules":[{"t":"set","p":"reset","pt":"msg","to":"reset","tot":"str"},{"t":"set","p":"payload","pt":"msg","to":"  ","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1220,"y":530,"wires":[["26cb0f27462f9cd6","ed397177cda95b5a"]]},{"id":"a77168c5af53b7ed","type":"debug","z":"1283f6a97005461c","name":"Message to get things done","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1480,"y":530,"wires":[]},{"id":"ed397177cda95b5a","type":"ui_text","z":"1283f6a97005461c","group":"574552148f91ef06","order":1,"width":"3","height":"1","name":"","label":"Message","format":"{{msg.payload}}","layout":"row-spread","x":1420,"y":490,"wires":[]},{"id":"574552148f91ef06","type":"ui_group","name":"Long press","tab":"bb73106a674aef89","order":3,"disp":true,"width":"6","collapse":false},{"id":"bb73106a674aef89","type":"ui_tab","name":"Button press examples","icon":"dashboard","order":41,"disabled":false,"hidden":false}]
Trying_to_learn Here is a simple function node to manage the double click for you (11 lines of code). Feed the button clicks to it as a standalone gate or add the code into your function node.
[{"id":"7e66b5252f600a3a","type":"function","z":"d867d702.3f5658","name":"Double Click Gate","func":"var dbl_click_time  = 500,   // ms - max time between clicks to be valid \n    time            = new Date().getTime();\nif (typeof(context.click1) === 'undefined' || time > context.click1 + dbl_click_time) context.click1 = 0;\nif (context.click1 === 0 ) { context.click1 = time; return; }\nelse {\n    var click2 = time;\n    var dbl_click = ((click2 - context.click1) < dbl_click_time) ? true : false;  // 500 ms\n    context.click1 = 0; \n    }\nif (dbl_click) return msg\nelse return;","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\ncontext.test = \"Okay here\";\n","finalize":"","libs":[],"x":710,"y":445,"wires":[["68ca8fe4c5e85133"]]}]
Thanks.
Reading the code....
Should like 2 also be a var line?
Ok, digging deeper...
As I read it:
Define dbl_click_time to 500.
(I'll skip line 2)
if (context.click1 === undefined or time > context.click1 + dbl_click_time) set the context of click1 to 0
Then, line 4:
if the context of click1 is 0, set the context click1 to time.
Although it is already over my head with it - sort of - why not put all that on one line?
Line 3 and 4.
Just asking.
Not needed, the first line has a comma.
This sets the first click time for the next click evaluation.
Try it. It'll work for you.
Please don't get me wrong, I am just trying to wrap my block head around it.
I am also torn between writing optimised code and writing each command on a separate line.
It is an interesting spin on what I was/am doing.
I guess I got where I am/was because I was trying to use the standard nodes to achieve what I wanted to do.
var a="a", b="b";
is no more optimised than declaring the variables separately. Personally I prefer to declare them separately, I find it simpler and less error prone. Do whichever you find easiest to understand. Understanding is much, much, much more important than supposed optimisation.
I agree with Colin. Personally, my goal hasn't ever been to optimize. My first goal is for the code to simply achieve what I need it to do, and my second goal is to be able to look at it 6 months later and easily understand what it's doing and how. Perhaps my third goal is to be able to quickly identify "adjustable parameters" in the code (such as "dbl_click_time") for change, which is why I tend to declare them all in the first set of lines.
If optimize means minimal number of code lines, here's the same gate with only 6 lines of code, works exactly the same way but harder to get a handle on months down the road.
[{"id":"0eb51c6b779d60a7","type":"function","z":"d867d702.3f5658","name":"Double Click Gate2","func":"if (typeof(context.click1) === 'undefined' || new Date().getTime() > context.click1 + 500) context.click1 = 0;\nif (context.click1 === 0 ) { context.click1 = new Date().getTime(); return; }\nelse { var dbl_click = ((new Date().getTime() - context.click1) < 500) ? true : false; \n    context.click1 = 0; }\nif (dbl_click) return msg\nelse return;","outputs":1,"noerr":0,"initialize":"// Code added here will be run once\n// whenever the node is started.\ncontext.test = \"Okay here\";\n","finalize":"","libs":[],"x":745,"y":330,"wires":[["68ca8fe4c5e85133"]]}]
