That is strange because the flow / node you have send me is OK and works as expected.
Perhaps send me your complete flow.
I forgot to tell you a couple of things:
Another couple of things...
But in the background of your screenshot it seams it looks like expected from the example
flow.
Did not understand what you've said.... Could be clearer?
in your screenshot I see that the ui-table example is working ...
I don`t know where your problem is. You have to show me your problem via screenshots or example flows. You can place a debug node on your table input (if the rest of your flow is to complicated). Copy the value of this debug node and place a change node with msg = json (paste). As done in the example showing my heating system.
Only something "is not working" is not enough that I can help you.
Maybe we've not understood...
The flow it's ok, but the properties like headerVisible o fitcolumns don't work at all.
[{"id":"9aa3d342.c6074","type":"debug","z":"1c2b2ce9.ba9843","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":789,"y":440,"wires":},{"id":"6d7787da.c81c28","type":"ui_table","z":"1c2b2ce9.ba9843","group":"99a97d4c.ef9a4","name":"Thermostats","order":1,"width":"16","height":"7","columns":,"outputs":1,"cts":true,"x":639,"y":440,"wires":[["9aa3d342.c6074"]]},{"id":"36d9d982.e513f6","type":"change","z":"1c2b2ce9.ba9843","name":"ui_control","rules":[{"t":"set","p":"ui_control","pt":"msg","to":"{"tabulator":{"movableColumns":false,"headerVisible":false,"columnResized":"function(column){ var newColumn = { field: column._column.field, visible: column._column.visible, width: column._column.width, widthFixed: column._column.widthFixed, widthStyled: column._column.widthStyled }; this.send({topic:this.config.topic,ui_control:{callback:'columnResized',columnWidths:newColumn}}); }","columnMoved":"function(column, columns){ var newColumns=; columns.forEach(function (column) { newColumns.push({'field': column._column.field}); }); this.send({topic:this.config.topic,ui_control:{callback:'columnMoved',columns:newColumns}}); }","groupHeader":"function (value, count, data, group) {return value + \"(\" + count + \" Termostat\"+((count>1) ? \"e\" : \"\") + \")\";}","columns":[{"formatterParams":{"target":"_blank"},"title":"ROom","field":"room","width":100,"frozen":true},{"formatterParams":{"target":"_blank"},"title":"Device","field":"name","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Type","field":"deviceType","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Measurements","columns":[{"formatterParams":{"target":"_blank"},"title":"target","field":"SET_TEMPERATURE-value","formatter":"function(cell, formatterParams, onRendered){return cell.getValue()+'°C';}","topCalc":"avg","width":100},{"formatterParams":{"target":"_blank","min":10,"max":25,"color":["blue","green","red"],"legend":"function (value) {return ' '+value+'°C';}","legendColor":"#101010","legendAlign":"left"},"title":"current","field":"ACTUAL_TEMPERATURE-value","formatter":"progress","topCalc":"avg","width":100},{"formatterParams":{"target":"_blank","min":0,"max":99,"color":["gray","orange","red"],"legend":"function (value) {return (value>0)? ' '+value+' %' : '-';}","legendColor":"#101010","legendAlign":"center"},"title":"Valve","field":"VALVE_STATE-value","formatter":"progress","topCalc":"max","width":100},{"formatterParams":{"target":"_blank","min":1.5,"max":4.6,"color":["red","orange","green"],"legend":"function (value) {return value+' V';}","legendColor":"#101010","legendAlign":"center"},"title":"Batt","field":"BATTERY_STATE-value","formatter":"progress","topCalc":"min","width":100}]},{"formatterParams":{"target":"_blank"},"title":"Settings","columns":[{"formatterParams":{"target":"_blank","min":0,"max":30,"color":["red","orange","green"],"legend":"function (value) { if (value>0) return \"\"+value+\" min\"; else return \"aus\"; }","legendColor":"#101010","legendAlign":"center"},"title":"Boost","field":"BOOST_STATE-value","formatter":"progress","width":100},{"formatterParams":{"target":"_blank","allowEmpty":true,"allowTruthy":true,"tickElement":"","crossElement":""},"title":"Auto","field":"AUTO_MODE-value","formatter":"tickCross","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Mode","field":"CONTROL_MODE-value","formatter":"function(cell, formatterParams, onRendered){ var html=\"<i class=\\\"\"; switch(cell.getValue()) { case 0: html+=\"fa fa-calendar-check-o\"; break; case 1: html+=\"fa fa-hand-o-up\"; break; case 2: html+=\"fa fa-suitcase\"; break; case 3: html+=\"fa fa-spinner fa-spin fa-fw\"; break; } html+='\\\">'; return html; }","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Auto","field":"AUTO_MODE-value","width":100,"align":"center"}]}]}}","tot":"json"}],"action":"","property":"","from":"","to":"","reg":false,"x":480,"y":440,"wires":[["6d7787da.c81c28"]]},{"id":"cd47172e.058238","type":"inject","z":"1c2b2ce9.ba9843","name":"","topic":"","payload":"[{"name":"MEQ0451495","room":"Bathroom","SET_TEMPERATURE-value":22,"ACTUAL_TEMPERATURE-value":21.8,"VALVE_STATE-value":90,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":true,"CONTROL_MODE-value":0},{"name":"MEQ1875547","room":"Living Room","SET_TEMPERATURE-value":12,"ACTUAL_TEMPERATURE-value":16.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":1},{"name":"MEQ1875538","room":"Living Room","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":19.5,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.6,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":2},{"name":"MEQ0447462","room":"Kitchen","SET_TEMPERATURE-value":17,"ACTUAL_TEMPERATURE-value":22.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":10,"AUTO_MODE-value":false,"CONTROL_MODE-value":3},{"name":"MEQ1875551","room":"Office","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":20.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ0447425","room":"Dining Room","SET_TEMPERATURE-value":19,"ACTUAL_TEMPERATURE-value":20.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875546","room":"Dining Room","SET_TEMPERATURE-value":20,"ACTUAL_TEMPERATURE-value":18.8,"VALVE_STATE-value":99,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ0447483","room":"Bedroom","SET_TEMPERATURE-value":17,"ACTUAL_TEMPERATURE-value":22.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875541","room":"Child","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":20.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875552","room":"Guest Room","SET_TEMPERATURE-value":20,"ACTUAL_TEMPERATURE-value":21.1,"VALVE_STATE-value":9,"BATTERY_STATE-value":2.8,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0}]","payloadType":"json","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":330,"y":440,"wires":[["36d9d982.e513f6"]]},{"id":"99a97d4c.ef9a4","type":"ui_group","name":"Group 2","tab":"919de4ce.62b498","order":2,"disp":true,"width":16},{"id":"919de4ce.62b498","type":"ui_tab","z":"","name":"copypaste","icon":"dashboard","disabled":false,"hidden":false}]
This one the debug node in the input of the table. As you can see, headerVisible: false is correct.
Scuse me for bad attached code.
{"_msgid":"3b695b23.c68cc4","topic":"","payload":[{"name":"MEQ0451495","room":"Bathroom","SET_TEMPERATURE-value":22,"ACTUAL_TEMPERATURE-value":21.8,"VALVE_STATE-value":90,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":true,"CONTROL_MODE-value":0},{"name":"MEQ1875547","room":"Living Room","SET_TEMPERATURE-value":12,"ACTUAL_TEMPERATURE-value":16.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":1},{"name":"MEQ1875538","room":"Living Room","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":19.5,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.6,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":2},{"name":"MEQ0447462","room":"Kitchen","SET_TEMPERATURE-value":17,"ACTUAL_TEMPERATURE-value":22.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":10,"AUTO_MODE-value":false,"CONTROL_MODE-value":3},{"name":"MEQ1875551","room":"Office","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":20.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ0447425","room":"Dining Room","SET_TEMPERATURE-value":19,"ACTUAL_TEMPERATURE-value":20.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875546","room":"Dining Room","SET_TEMPERATURE-value":20,"ACTUAL_TEMPERATURE-value":18.8,"VALVE_STATE-value":99,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ0447483","room":"Bedroom","SET_TEMPERATURE-value":17,"ACTUAL_TEMPERATURE-value":22.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875541","room":"Child","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":20.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875552","room":"Guest Room","SET_TEMPERATURE-value":20,"ACTUAL_TEMPERATURE-value":21.1,"VALVE_STATE-value":9,"BATTERY_STATE-value":2.8,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0}],"ui_control":{"tabulator":{"movableColumns":false,"headerVisible":false,"columnResized":"function(column){ var newColumn = { field: column._column.field, visible: column._column.visible, width: column._column.width, widthFixed: column._column.widthFixed, widthStyled: column._column.widthStyled }; this.send({topic:this.config.topic,ui_control:{callback:'columnResized',columnWidths:newColumn}}); }","columnMoved":"function(column, columns){ var newColumns=; columns.forEach(function (column) { newColumns.push({'field': column._column.field}); }); this.send({topic:this.config.topic,ui_control:{callback:'columnMoved',columns:newColumns}}); }","groupHeader":"function (value, count, data, group) {return value + "(" + count + " Termostat"+((count>1) ? "e" : "") + ")";}","columns":[{"formatterParams":{"target":"_blank"},"title":"ROom","field":"room","width":100,"frozen":true},{"formatterParams":{"target":"_blank"},"title":"Device","field":"name","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Type","field":"deviceType","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Measurements","columns":[{"formatterParams":{"target":"_blank"},"title":"target","field":"SET_TEMPERATURE-value","formatter":"function(cell, formatterParams, onRendered){return cell.getValue()+'°C';}","topCalc":"avg","width":100},{"formatterParams":{"target":"_blank","min":10,"max":25,"color":["blue","green","red"],"legend":"function (value) {return ' '+value+'°C';}","legendColor":"#101010","legendAlign":"left"},"title":"current","field":"ACTUAL_TEMPERATURE-value","formatter":"progress","topCalc":"avg","width":100},{"formatterParams":{"target":"_blank","min":0,"max":99,"color":["gray","orange","red"],"legend":"function (value) {return (value>0)? ' '+value+' %' : '-';}","legendColor":"#101010","legendAlign":"center"},"title":"Valve","field":"VALVE_STATE-value","formatter":"progress","topCalc":"max","width":100},{"formatterParams":{"target":"_blank","min":1.5,"max":4.6,"color":["red","orange","green"],"legend":"function (value) {return value+' V';}","legendColor":"#101010","legendAlign":"center"},"title":"Batt","field":"BATTERY_STATE-value","formatter":"progress","topCalc":"min","width":100}]},{"formatterParams":{"target":"_blank"},"title":"Settings","columns":[{"formatterParams":{"target":"_blank","min":0,"max":30,"color":["red","orange","green"],"legend":"function (value) { if (value>0) return ""+value+" min"; else return "aus"; }","legendColor":"#101010","legendAlign":"center"},"title":"Boost","field":"BOOST_STATE-value","formatter":"progress","width":100},{"formatterParams":{"target":"_blank","allowEmpty":true,"allowTruthy":true,"tickElement":"","crossElement":""},"title":"Auto","field":"AUTO_MODE-value","formatter":"tickCross","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Mode","field":"CONTROL_MODE-value","formatter":"function(cell, formatterParams, onRendered){ var html="<i class=\""; switch(cell.getValue()) { case 0: html+="fa fa-calendar-check-o"; break; case 1: html+="fa fa-hand-o-up"; break; case 2: html+="fa fa-suitcase"; break; case 3: html+="fa fa-spinner fa-spin fa-fw"; break; } html+='\">'; return html; }","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Auto","field":"AUTO_MODE-value","width":100,"align":"center"}]}]}}}
I'm sorry I'm making a disaster... This one is the debug node....
14/4/2020, 09:50:59node: 1a5af8c.edaa407
msg : Object
object
_msgid: "3b695b23.c68cc4"
topic: ""
payload: array[10]
ui_control: object
tabulator: object
movableColumns: false
columnResized: "function(column){ var newColumn = { field: column._column.field, visible: column._column.visible, width: column._column.width, widthFixed: column._column.widthFixed, widthStyled: column._column.widthStyled }; this.send({topic:this.config.topic,ui_control:{callback:'columnResized',columnWidths:newColumn}}); }"
columnMoved: "function(column, columns){ var newColumns=; columns.forEach(function (column) { newColumns.push({'field': column._column.field}); }); this.send({topic:this.config.topic,ui_control:{callback:'columnMoved',columns:newColumns}}); }"
groupHeader: "function (value, count, data, group) {return value + "(" + count + " Termostat"+((count>1) ? "e" : "") + ")";}"
columns: array[5]
0: object
formatterParams: object
title: "ROom"
field: "room"
width: 100
frozen: true
1: object
title: "Device"
field: "name"
width: 100
align: "center"
2: object
3: object
4: object
@frankzappa please go and read this FAQ - How to share code or flow json - then edit your posts above so they are readable and importable. Thanks
{"_msgid":"8caa07e2.990bd8","topic":"","payload":[{"name":"MEQ0451495","room":"Bathroom","SET_TEMPERATURE-value":22,"ACTUAL_TEMPERATURE-value":21.8,"VALVE_STATE-value":90,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":true,"CONTROL_MODE-value":0},{"name":"MEQ1875547","room":"Living Room","SET_TEMPERATURE-value":12,"ACTUAL_TEMPERATURE-value":16.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":1},{"name":"MEQ1875538","room":"Living Room","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":19.5,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.6,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":2},{"name":"MEQ0447462","room":"Kitchen","SET_TEMPERATURE-value":17,"ACTUAL_TEMPERATURE-value":22.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":10,"AUTO_MODE-value":false,"CONTROL_MODE-value":3},{"name":"MEQ1875551","room":"Office","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":20.2,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ0447425","room":"Dining Room","SET_TEMPERATURE-value":19,"ACTUAL_TEMPERATURE-value":20.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875546","room":"Dining Room","SET_TEMPERATURE-value":20,"ACTUAL_TEMPERATURE-value":18.8,"VALVE_STATE-value":99,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ0447483","room":"Bedroom","SET_TEMPERATURE-value":17,"ACTUAL_TEMPERATURE-value":22.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875541","room":"Child","SET_TEMPERATURE-value":18,"ACTUAL_TEMPERATURE-value":20.4,"VALVE_STATE-value":0,"BATTERY_STATE-value":2.7,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0},{"name":"MEQ1875552","room":"Guest Room","SET_TEMPERATURE-value":20,"ACTUAL_TEMPERATURE-value":21.1,"VALVE_STATE-value":9,"BATTERY_STATE-value":2.8,"BOOST_STATE-value":0,"AUTO_MODE-value":false,"CONTROL_MODE-value":0}],"ui_control":{"tabulator":{"movableColumns":false,"headerVisible":false,"columnResized":"function(column){ var newColumn = { field: column._column.field, visible: column._column.visible, width: column._column.width, widthFixed: column._column.widthFixed, widthStyled: column._column.widthStyled }; this.send({topic:this.config.topic,ui_control:{callback:'columnResized',columnWidths:newColumn}}); }","columnMoved":"function(column, columns){ var newColumns=[]; columns.forEach(function (column) { newColumns.push({'field': column._column.field}); }); this.send({topic:this.config.topic,ui_control:{callback:'columnMoved',columns:newColumns}}); }","groupHeader":"function (value, count, data, group) {return value + \"<span style='color:#d00; margin-left:10px;'>(\" + count + \" Termostat\"+((count>1) ? \"e\" : \"\") + \")</span>\";}","columns":[{"formatterParams":{"target":"_blank"},"title":"ROom","field":"room","width":100,"frozen":true},{"formatterParams":{"target":"_blank"},"title":"Device","field":"name","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Type","field":"deviceType","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Measurements","columns":[{"formatterParams":{"target":"_blank"},"title":"target","field":"SET_TEMPERATURE-value","formatter":"function(cell, formatterParams, onRendered){return cell.getValue()+'°C';}","topCalc":"avg","width":100},{"formatterParams":{"target":"_blank","min":10,"max":25,"color":["blue","green","red"],"legend":"function (value) {return ' '+value+'°C';}","legendColor":"#101010","legendAlign":"left"},"title":"current","field":"ACTUAL_TEMPERATURE-value","formatter":"progress","topCalc":"avg","width":100},{"formatterParams":{"target":"_blank","min":0,"max":99,"color":["gray","orange","red"],"legend":"function (value) {return (value>0)? ' '+value+' %' : '-';}","legendColor":"#101010","legendAlign":"center"},"title":"Valve","field":"VALVE_STATE-value","formatter":"progress","topCalc":"max","width":100},{"formatterParams":{"target":"_blank","min":1.5,"max":4.6,"color":["red","orange","green"],"legend":"function (value) {return value+' V';}","legendColor":"#101010","legendAlign":"center"},"title":"Batt","field":"BATTERY_STATE-value","formatter":"progress","topCalc":"min","width":100}]},{"formatterParams":{"target":"_blank"},"title":"Settings","columns":[{"formatterParams":{"target":"_blank","min":0,"max":30,"color":["red","orange","green"],"legend":"function (value) { if (value>0) return \"<span style='color:#101010;'>\"+value+\" min</span>\"; else return \"<span style='color:#A0A0A0;'>aus</span>\"; }","legendColor":"#101010","legendAlign":"center"},"title":"Boost","field":"BOOST_STATE-value","formatter":"progress","width":100},{"formatterParams":{"target":"_blank","allowEmpty":true,"allowTruthy":true,"tickElement":"<i class='fa fa-clock-o'></i>","crossElement":"<i class='fa fa-ban'></i>"},"title":"Auto","field":"AUTO_MODE-value","formatter":"tickCross","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Mode","field":"CONTROL_MODE-value","formatter":"function(cell, formatterParams, onRendered){ var html=\"<i class=\\\"\"; switch(cell.getValue()) { case 0: html+=\"fa fa-calendar-check-o\"; break; case 1: html+=\"fa fa-hand-o-up\"; break; case 2: html+=\"fa fa-suitcase\"; break; case 3: html+=\"fa fa-spinner fa-spin fa-fw\"; break; } html+='\\\"></i>'; return html; }","width":100,"align":"center"},{"formatterParams":{"target":"_blank"},"title":"Auto","field":"AUTO_MODE-value","width":100,"align":"center"}]}]}}}
Another strange thing...
I've just add the ui-e-table, just to make some attempts.
Now there are (and work correctly!!) the two callbacks that I was trying to run before the system crashed (cellclick and celledited) but they aren't on my flow. Is there a cache or other?
I'm getting crying...
Just discovered that the ui-e-table by default give the 2 callbacks cellclick and celledited, mea culpa...
I will continue with this one because of the problems encountered (options like headerVisible and all the others).
Thanks for the patience...
Bye.
