# Can I use the Worldmap nodes with UIBUILDER? (Yes)
**URL:** <https://discourse.nodered.org/t/can-i-use-the-worldmap-nodes-with-uibuilder-yes/87890>\
**Category:** FAQs\
**Tags:** uibuilder\
**Created:** [12 May 2024 10:11 UTC](https://discourse.nodered.org/t/can-i-use-the-worldmap-nodes-with-uibuilder-yes/87890 "2024-05-12T10:11:05Z")\
**Post date:** [12 May 2024 10:34 UTC](https://discourse.nodered.org/t/can-i-use-the-worldmap-nodes-with-uibuilder-yes/87890/2 "2024-05-12T10:34:08Z")
By the way, using the [LeafletJS](https://leafletjs.com) library directly (this is the same library that worldmap uses) is not really much harder since UIBUILDER already provides comms between Node-RED and the browser.
Add the leaflet js library and css to your page, add a div with an id="map" (so you can use leaflet's examples). Then add the example code from their website.
To send a user click on the map back to Node-RED:
function onMapClick(e) {
    // console.log('leaflet click', e)
    uibuilder.send({topic: 'leaflet click', payload: e.latlng})
That's it!
Now you can build your own map apps 😀
_[View the full topic](https://discourse.nodered.org/t/can-i-use-the-worldmap-nodes-with-uibuilder-yes/87890)._
