# Can't display base64 QR code in Template
**URL:** <https://discourse.nodered.org/t/cant-display-base64-qr-code-in-template/51032>\
**Created:** [14 September 2021 20:31 UTC](https://discourse.nodered.org/t/cant-display-base64-qr-code-in-template/51032 "2021-09-14T20:31:20Z")\
**Post date:** [15 September 2021 07:02 UTC](https://discourse.nodered.org/t/cant-display-base64-qr-code-in-template/51032/4 "2021-09-15T07:02:58Z")
This works for me...
![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/3/8/38ac566e3c07bb0ad53fe45f15c7258ed4592890.png)
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/6/f/6f43d73643998c201d8df43ea398d4c065361086.png)
 ![image](https://us1.discourse-cdn.com/flex026/uploads/nodered/original/3X/c/e/ce3d685c988fc772f8616b1f08341855d6708448.png)
Uses node-red-contrib-image-tools
Demo flow...
[{"id":"5bb019b65d5f0af7","type":"inject","z":"af952aeaa20f4f97","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":1330,"y":680,"wires":[["f62c2ee556bf4e86"]]},{"id":"f62c2ee556bf4e86","type":"Barcode Generator","z":"af952aeaa20f4f97","name":"","data":"www.google.com","dataType":"str","barcode":"qrcode","barcodeType":"barcode","options":"","optionsType":"ui","sendProperty":"payload","props":[{"p":"rotate","v":"N","vt":"str"},{"p":"includetext","v":"true","vt":"bool"},{"p":"textxalign","v":"center","vt":"str"}],"x":1480,"y":680,"wires":[["72583360f1fa1443"]]},{"id":"72583360f1fa1443","type":"jimp-image","z":"af952aeaa20f4f97","name":"","data":"payload","dataType":"msg","ret":"b64","parameter1":"","parameter1Type":"msg","parameter2":"","parameter2Type":"msg","parameter3":"","parameter3Type":"msg","parameter4":"","parameter4Type":"msg","parameter5":"","parameter5Type":"msg","parameter6":"","parameter6Type":"msg","parameter7":"","parameter7Type":"msg","parameter8":"","parameter8Type":"msg","sendProperty":"payload","sendPropertyType":"msg","parameterCount":0,"jimpFunction":"none","selectedJimpFunction":{"name":"none","fn":"none","description":"Just loads the image.","parameters":[]},"x":1630,"y":680,"wires":[["0f10978fe0469748"]]},{"id":"0f10978fe0469748","type":"image viewer","z":"af952aeaa20f4f97","name":"","width":160,"data":"payload","dataType":"msg","active":true,"x":1790,"y":680,"wires":[["eb155874df4dc7f4"]]},{"id":"eb155874df4dc7f4","type":"ui_template","z":"af952aeaa20f4f97","group":"a348b0ef9d248038","name":"","order":3,"width":"6","height":"5","format":"<img src=\"{{msg.payload}}\" style=\"height: 100%;\" />","storeOutMessages":true,"fwdInMessages":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1960,"y":680,"wires":[[]]},{"id":"a348b0ef9d248038","type":"ui_group","name":"Default","tab":"3316deba5234ba30","order":1,"disp":true,"width":"6","collapse":false,"className":""},{"id":"3316deba5234ba30","type":"ui_tab","name":"test","icon":"dashboard","disabled":false,"hidden":false}]
_[View the full topic](https://discourse.nodered.org/t/cant-display-base64-qr-code-in-template/51032)._
