No, its more likely the OP does not have the build tools installed.
- You tried to install at path
C:\Users\Justst03\- I suspect this should beC:\Users\Justst03\.node-red\ - node-red is not tested on NODE V17 - so i would uninstall that & install NODE V16 LTS or NODE V14 LTS
- when you install NODE, there is a checkbox to install build tools - this must be checked if you are to install any nodes that have a compilation step
