# Change border color to text input node
**URL:** <https://discourse.nodered.org/t/change-border-color-to-text-input-node/13288>\
**Created:** [15 July 2019 08:25 UTC](https://discourse.nodered.org/t/change-border-color-to-text-input-node/13288 "2019-07-15T08:25:56Z")\
**Showing post:** 10
**Post date:** [13 July 2022 15:30 UTC](https://discourse.nodered.org/t/change-border-color-to-text-input-node/13288/10 "2022-07-13T15:30:14Z")
If you look a bit closer - at the end of that solution is this...
> [@Dashboard element css classes](https://discourse.nodered.org/t/dashboard-element-css-classes/46447/2):
> but I agree, having the ability to specify an additional `class` or classes on the UI items like button and label etc would simplify this somewhat.
That comment was some time ago and custom classes are now supported in dashboard - so while the above still works (it is valid CSS after all) there is a more elegant solution using classes now.
hope that helps.
_[View the full topic](https://discourse.nodered.org/t/change-border-color-to-text-input-node/13288)._
