# Change layout of the custom nodes
**URL:** <https://discourse.nodered.org/t/change-layout-of-the-custom-nodes/14692>\
**Created:** [23 August 2019 09:08 UTC](https://discourse.nodered.org/t/change-layout-of-the-custom-nodes/14692 "2019-08-23T09:08:13Z")\
**Showing post:** 3
**Author:** ![Khk2000](https://avatars.discourse-cdn.com/v4/letter/k/278dde/32.png) [@Khk2000](https://discourse.nodered.org/u/Khk2000)\
**Post date:** [27 September 2023 06:14 UTC](https://discourse.nodered.org/t/change-layout-of-the-custom-nodes/14692/3 "2023-09-27T06:14:18Z")
Then, how is it possible to change node styling as others were doing, apart from changing node icons
> [@Q: Tiles type panels](https://discourse.nodered.org/t/q-tiles-type-panels/35245):
> I have a play with the Dashboard and it fine for a basic design i have ended up with but i'd like to get a little bit more elegant. Used the Switch node to do this. [Screenshot 2020-11-02 213735] but i'd like to try make it look like this if its possible.. Not to fussed about the - + bit.. just more doing the tile effect. probably lots of clever CCS no doubt. [Screenshot 2020-11-02 214023] Any pointers if its even possible. ta I've tried doing it as a Button in separate groups .. but i…
> [@How to change the buttons in dashboard](https://discourse.nodered.org/t/how-to-change-the-buttons-in-dashboard/66116):
> node red v3 id like to know how you change the boring buttons in dashboard - im making an 8 channel relay switch board via usb for my overlander car ... id like to change from this .. to something like this style - like simple easy read vehicle buttons .. got it all working so far and works fine just want to change buttons how is it done?
_[View the full topic](https://discourse.nodered.org/t/change-layout-of-the-custom-nodes/14692)._
