# Changing the inject node repeat option from UI
**URL:** <https://discourse.nodered.org/t/changing-the-inject-node-repeat-option-from-ui/11935>\
**Created:** [7 June 2019 10:14 UTC](https://discourse.nodered.org/t/changing-the-inject-node-repeat-option-from-ui/11935 "2019-06-07T10:14:14Z")\
**Showing post:** 6
**Post date:** [17 June 2019 07:57 UTC](https://discourse.nodered.org/t/changing-the-inject-node-repeat-option-from-ui/11935/6 "2019-06-17T07:57:46Z")
Unfortunately your flow isn't currently importable.Please read the following post [How to share code or flow json](https://discourse.nodered.org/t/how-to-share-code-or-flow-json/506) and then edit the above message.
_[View the full topic](https://discourse.nodered.org/t/changing-the-inject-node-repeat-option-from-ui/11935)._
