# Code Editor Backgroud or Theme
**URL:** <https://discourse.nodered.org/t/code-editor-backgroud-or-theme/89942>\
**Tags:** docker\
**Created:** [2 August 2024 00:18 UTC](https://discourse.nodered.org/t/code-editor-backgroud-or-theme/89942 "2024-08-02T00:18:56Z")\
**Post date:** [2 August 2024 13:09 UTC](https://discourse.nodered.org/t/code-editor-backgroud-or-theme/89942/4 "2024-08-02T13:09:28Z")
> [@slapme](#):
> it changed most things but not the main editor background
what is main editor? show us.
If you mean the code editor (the Monaco code editor) then if the theme does not set by the node-red theme, you can set the monaco theme yourself [How to use themes with Monaco editor - #7 by Steve-Mcl](https://discourse.nodered.org/t/how-to-use-themes-with-monaco-editor/48310/7)
options include "vs", "vs-dark" and anything you see in here: [node-red/packages/node\_modules/@node-red/editor-client/src/vendor/monaco/dist/theme at master · node-red/node-red · GitHub](https://github.com/node-red/node-red/tree/master/packages/node_modules/%40node-red/editor-client/src/vendor/monaco/dist/theme) e.g. "ace", "dawn", "dracula", "birds-of-paradise" etc.
_[View the full topic](https://discourse.nodered.org/t/code-editor-backgroud-or-theme/89942)._
