# Combining values from an Array into a single word
**URL:** <https://discourse.nodered.org/t/combining-values-from-an-array-into-a-single-word/90003>\
**Created:** [5 August 2024 14:18 UTC](https://discourse.nodered.org/t/combining-values-from-an-array-into-a-single-word/90003 "2024-08-05T14:18:33Z")\
**Post date:** [5 August 2024 15:13 UTC](https://discourse.nodered.org/t/combining-values-from-an-array-into-a-single-word/90003/2 "2024-08-05T15:13:02Z")
Sharing data as an image will not help people help you, if you shared as text in correct format you may find more help.
There’s a great page in the docs ([Working with messages : Node-RED](https://nodered.org/docs/user-guide/messages)) that will explain how to use the debug panel to find the right path/value for any data item.
Also make sure you post the info correctly
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/combining-values-from-an-array-into-a-single-word/90003)._
