# Configuring HTTP Request for API call
**URL:** <https://discourse.nodered.org/t/configuring-http-request-for-api-call/95592>\
**Created:** [23 February 2025 14:33 UTC](https://discourse.nodered.org/t/configuring-http-request-for-api-call/95592 "2025-02-23T14:33:41Z")\
**Showing post:** 5
**Post date:** [23 February 2025 15:05 UTC](https://discourse.nodered.org/t/configuring-http-request-for-api-call/95592/5 "2025-02-23T15:05:23Z")
Your flow is corrupt due to not posting code in the correct way
````auto
   code goes here
What is the response you get from the http resquest node?
Did you try what I said?
[edit]
The browser is a GET request but you set the http request to POST.
To append the query string mag.payload needs to be a object.
You do not require the JSON node, unless you want a JSON(string) returned rather than a Javascript object.
example flow
[{"id":"076b0c640872f1aa","type":"inject","z":"d1395164b4eec73e","name":"On","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"Switch","payload":"{\"oid\":\"b05dd514\",\"prop\":\"command\",\"value\":\"off\"}","payloadType":"json","x":450,"y":5800,"wires":[["06748d9fc38754f0"]]},{"id":"06748d9fc38754f0","type":"http request","z":"d1395164b4eec73e","name":"Switch Extra","method":"GET","ret":"obj","paytoqs":"query","url":"http://192.168.1.118/iungo/api_request/object_prop_set","tls":"","persist":false,"proxy":"","insecureHTTPParser":true,"authType":"","senderr":false,"headers":[],"x":630,"y":5800,"wires":[["a69505ee9895d0ec","9ed11ab460e04bc0"]]},{"id":"a69505ee9895d0ec","type":"debug","z":"d1395164b4eec73e","name":"debug 8","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":880,"y":5720,"wires":[]},{"id":"9ed11ab460e04bc0","type":"debug","z":"d1395164b4eec73e","name":"debug 1","active":true,"tosidebar":false,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1000,"y":5800,"wires":[]}]
> [@JPHR](#):
> exactly what I described above with all those ? between headers.
What you call `headers` are properties of the query string. headers are a completely different thing.
_[View the full topic](https://discourse.nodered.org/t/configuring-http-request-for-api-call/95592)._
