also is the basic api key in base64 encoded
Finally you flow.json is corrupt as you have not posted it correctly
code goes here
icon.
[edit]
you can try this example If it does not work try setting the method to POST to.
[{"id":"7b7a69fa8e099eed","type":"inject","z":"d1395164b4eec73e","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":800,"y":1740,"wires":[["0a03c04733728ae0"]]},{"id":"0a03c04733728ae0","type":"function","z":"d1395164b4eec73e","name":"function 1","func":"var d = Math.floor(new Date().getTime() / 1000);\n var token = 12345678;\n \n msg.url = \"https://172.16.6.2/api\";\n msg.rejectUnauthorized = false;\n \n msg.headers = { 'Authorization': 'Basic ' + token };\n //msg.headers = {}; \n //msg.headers['Authorization'] = 'Basic 12345678';\n \n msg.timeout = 15;\n \n msg.payload = {\n \"command\":\"set_target\",\n \"time\": d,\n \"value\": \"1800\"\n };\n \n return msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":980,"y":1740,"wires":[["89fb703cf6594aac","8b2d9ea2bbaf71ce"]]},{"id":"89fb703cf6594aac","type":"http request","z":"d1395164b4eec73e","name":"","method":"GET","ret":"obj","paytoqs":"body","url":"","tls":"","persist":false,"proxy":"","insecureHTTPParser":false,"authType":"","senderr":false,"headers":[],"credentials":{"user":"","password":""},"x":1210,"y":1740,"wires":[["59eaed8789db5ee7"]]},{"id":"8b2d9ea2bbaf71ce","type":"debug","z":"d1395164b4eec73e","name":"debug 2","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1220,"y":1820,"wires":[]},{"id":"59eaed8789db5ee7","type":"debug","z":"d1395164b4eec73e","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":1350,"y":1740,"wires":[]}]
