I have not used that node, but looking at the readme it seems that if you select the array output then it aught to send an empty array if there are no matches, but that seems not to be the case. I would say that is a deficiency in the node, it might be worth raising an issue against it.
It also doesn't appear to generate anything in a Status node or a Catch node.
