# Control node-red-contrib-ramp-thermostat via dashboard
**URL:** <https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006>\
**Created:** [18 November 2018 15:45 UTC](https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006 "2018-11-18T15:45:56Z")\
**Post date:** [18 November 2018 16:10 UTC](https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006/2 "2018-11-18T16:10:31Z")
For the profiles you could have a dropdown list of profiles to select from and make it so that it reverts to the default profile at the end of the day (or whatever). For manual temp have an Override switch and a temperature select (I use a drop down with 0.5 degree intervals for this, but you could use an up/down selector.
_[View the full topic](https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006)._
