# Control node-red-contrib-ramp-thermostat via dashboard
**URL:** <https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006>\
**Created:** [18 November 2018 15:45 UTC](https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006 "2018-11-18T15:45:56Z")\
**Showing post:** 9
**Author:** ![seth350](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/seth350/32/4617_2.png) [@seth350](https://discourse.nodered.org/u/seth350)\
**Post date:** [18 November 2018 19:12 UTC](https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006/9 "2018-11-18T19:12:31Z")
Indeed sir.
That seems to be the simplest way. ecobee also has the option to average all of the room temperatures, or act on the temperature in the room that has occupancy. Ecobee calls this their “Follow Me” option.
The sensors have motion sensing and temperature.
Also, the mode won’t be truly manual. Unless you want the “Until I change it” option, then it acts as a standard thermostat. All other options are automatic.
Ecobee also provides a cancel button when the scheduled profile has been deviated from. Hitting the cancel button resumes normal schedule.
So if current setpoint does not equal scheduled setpoint, show cancel button. Then have the click event set current setpoint to scheduled setpoint.
_[View the full topic](https://discourse.nodered.org/t/control-node-red-contrib-ramp-thermostat-via-dashboard/5006)._
