# Convert a 16 bit integer to 16 discrete outputs
**URL:** <https://discourse.nodered.org/t/convert-a-16-bit-integer-to-16-discrete-outputs/20777>\
**Created:** [23 January 2020 16:10 UTC](https://discourse.nodered.org/t/convert-a-16-bit-integer-to-16-discrete-outputs/20777 "2020-01-23T16:10:08Z")\
**Showing post:** 7
**Author:** ![Andrei](https://sea2.discourse-cdn.com/flex026/user_avatar/discourse.nodered.org/andrei/32/10446_2.png) [@Andrei](https://discourse.nodered.org/u/Andrei)\
**Post date:** [23 January 2020 18:57 UTC](https://discourse.nodered.org/t/convert-a-16-bit-integer-to-16-discrete-outputs/20777/7 "2020-01-23T18:57:01Z")
There is a very similar question in this post. There is an alternative solution there.
> [@Split to different outputs](https://discourse.nodered.org/t/split-to-different-outputs/5773):
> I am using a split node to tear apart a 8 bit binary number in string with fixed lenght of 1. Is there a way to split it in different outputs ? Is it possible to use the switch node outputs with the split node to separate them or add outputs in the split node itself? Thank you
_[View the full topic](https://discourse.nodered.org/t/convert-a-16-bit-integer-to-16-discrete-outputs/20777)._
