It's this line you have to modify
client.publish("distance/result", str(Distance*0.0254))
What is the name of the variable that holds the object name?
i've added object_detected = classNames [classIds[i]] in the 83th line
So you have to return it also like
return object_width, bbox, object_center_x, object_center_y, object_detected
And in your call to function findObjects
object_width_in_frame, bbox, OB_X ,OB_Y, OB_detected = findObjects(outputs,img)
then change this line to also publish info about found object
client.publish("distance/result", str(Distance*0.0254) + ' Object detected: ' + OB_detected)
You need also to change this line (for the ref image)
ref_image_object_width, _, _, _, _ = findObjects(outputs,ref_image)
Thank u so much , It works !
Last question please , how can i set an alarm in node red (for exemple when the distance is <0.5 m ==> launches alarm )
When you say alarm in Node-RED there are so many possibilities - from simple to very advanced
A simple starter is in the flow below. I have extended the flow we have already with some nodes. It shows a notification in the Node-RED dashboard when the distance is below 0.5
It works like this:
To make more advanced alarms you can think of introducing some audio notificaation, send the alarm to your phone using Telegram etc etc. Many possibilities.
[{"id":"f097b105.f85e5","type":"mqtt in","z":"fcecd26b.a4283","name":"","topic":"distance/result","qos":"2","datatype":"auto","broker":"56c5f0f2.9f483","nl":false,"rap":true,"rh":0,"x":220,"y":740,"wires":[["3767954f.23f1ba","5f43e95e.1947f8"]]},{"id":"c76a1e70.41db4","type":"debug","z":"fcecd26b.a4283","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":810,"y":680,"wires":[]},{"id":"340384a4.30f80c","type":"ui_toast","z":"fcecd26b.a4283","position":"top right","displayTime":"","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":830,"y":740,"wires":[]},{"id":"3767954f.23f1ba","type":"change","z":"fcecd26b.a4283","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number($split(payload, ' ')[0])\t","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"Distance is to short","tot":"str"},{"t":"set","p":"timeout","pt":"msg","to":"5","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":740,"wires":[["be555a39.858278"]]},{"id":"5e391542.72ed5c","type":"inject","z":"fcecd26b.a4283","name":"> 0.5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0.6 Object detected: person","payloadType":"str","x":190,"y":800,"wires":[["3767954f.23f1ba"]]},{"id":"4330c723.0f5798","type":"inject","z":"fcecd26b.a4283","name":"< 0.5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0.3 Object detected: person","payloadType":"str","x":190,"y":840,"wires":[["3767954f.23f1ba"]]},{"id":"be555a39.858278","type":"switch","z":"fcecd26b.a4283","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"0.5","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":610,"y":740,"wires":[["340384a4.30f80c","c76a1e70.41db4"]]},{"id":"5f43e95e.1947f8","type":"debug","z":"fcecd26b.a4283","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":430,"y":680,"wires":[]},{"id":"56c5f0f2.9f483","type":"mqtt-broker","name":"","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""}]
Want to use " node-red-contrib-ui-led " ( a simple led status indicator on dashboard)
if the distance is > 0.5 m : the color of led will be green
then if distance < 0.5m gives a red color
Well, that little thing you should be able to figure out. What have you tried so far?
It looks like you have only one output in your switch node. What is it doing?
You are on the right track, very good!! I thought the same idea would work and I needed to use some more nodes. I added a new path from the original 3 rules switch (just to keep the notification we already had). In there, the switch checks if the distance is < 0.5 or higher. Depending on, it sends the message to one of the change nodes where the payload is set to boolean either true or false. The message is then carried over to the ui_led node that shows green or red
[{"id":"f097b105.f85e5","type":"mqtt in","z":"fcecd26b.a4283","name":"","topic":"distance/result","qos":"2","datatype":"auto","broker":"56c5f0f2.9f483","nl":false,"rap":true,"rh":0,"x":220,"y":740,"wires":[["3767954f.23f1ba","5f43e95e.1947f8"]]},{"id":"c76a1e70.41db4","type":"debug","z":"fcecd26b.a4283","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":890,"y":680,"wires":[]},{"id":"340384a4.30f80c","type":"ui_toast","z":"fcecd26b.a4283","position":"top right","displayTime":"","highlight":"","sendall":true,"outputs":0,"ok":"OK","cancel":"","raw":false,"topic":"","name":"","x":910,"y":740,"wires":[]},{"id":"3767954f.23f1ba","type":"change","z":"fcecd26b.a4283","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$number($split(payload, ' ')[0])\t","tot":"jsonata"},{"t":"set","p":"topic","pt":"msg","to":"Distance is to short","tot":"str"},{"t":"set","p":"timeout","pt":"msg","to":"5","tot":"num"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":740,"wires":[["be555a39.858278","f7aeecd2.c019a"]]},{"id":"5e391542.72ed5c","type":"inject","z":"fcecd26b.a4283","name":"> 0.5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0.6 Object detected: person","payloadType":"str","x":190,"y":800,"wires":[["3767954f.23f1ba"]]},{"id":"4330c723.0f5798","type":"inject","z":"fcecd26b.a4283","name":"< 0.5","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"0.3 Object detected: person","payloadType":"str","x":190,"y":840,"wires":[["3767954f.23f1ba"]]},{"id":"be555a39.858278","type":"switch","z":"fcecd26b.a4283","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"0.5","vt":"num"}],"checkall":"true","repair":false,"outputs":1,"x":610,"y":740,"wires":[["340384a4.30f80c","c76a1e70.41db4"]]},{"id":"5f43e95e.1947f8","type":"debug","z":"fcecd26b.a4283","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":430,"y":680,"wires":[]},{"id":"78b8c5b1.275bdc","type":"ui_led","z":"fcecd26b.a4283","order":1,"group":"16030ced.45add3","width":0,"height":0,"label":"","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"false","valueType":"bool"},{"color":"#008000","value":"true","valueType":"bool"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":950,"y":840,"wires":[]},{"id":"f7aeecd2.c019a","type":"switch","z":"fcecd26b.a4283","name":"","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"0.5","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":610,"y":840,"wires":[["254bf5f4.a127fa"],["649219f4.80a1c8"]]},{"id":"254bf5f4.a127fa","type":"change","z":"fcecd26b.a4283","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":820,"wires":[["78b8c5b1.275bdc"]]},{"id":"649219f4.80a1c8","type":"change","z":"fcecd26b.a4283","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"true","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":780,"y":860,"wires":[["78b8c5b1.275bdc"]]},{"id":"56c5f0f2.9f483","type":"mqtt-broker","name":"","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"protocolVersion":"4","keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","birthMsg":{},"closeTopic":"","closeQos":"0","closePayload":"","closeMsg":{},"willTopic":"","willQos":"0","willPayload":"","willMsg":{},"sessionExpiry":""},{"id":"16030ced.45add3","type":"ui_group","name":"Test","tab":"aed64a14.9adfe8","order":1,"disp":true,"width":"14","collapse":false},{"id":"aed64a14.9adfe8","type":"ui_tab","name":"Test","icon":"dashboard","disabled":false,"hidden":false}]
this is perfect , thank u so much
