# Convert the time input to local time zone in node red through moment function
**URL:** <https://discourse.nodered.org/t/convert-the-time-input-to-local-time-zone-in-node-red-through-moment-function/58206>\
**Tags:** database\
**Created:** [12 February 2022 10:57 UTC](https://discourse.nodered.org/t/convert-the-time-input-to-local-time-zone-in-node-red-through-moment-function/58206 "2022-02-12T10:57:41Z")\
**Post date:** [12 February 2022 11:25 UTC](https://discourse.nodered.org/t/convert-the-time-input-to-local-time-zone-in-node-red-through-moment-function/58206/4 "2022-02-12T11:25:06Z")
Please
In order to make the flow importable it is necessary to surround your code with three backticks (also known as a left quote or backquote `````)
````auto
   code goes here
In the meantime, provided the timestamps in the database are in UTC (as they should be) then you should not need to do any conversion.
_[View the full topic](https://discourse.nodered.org/t/convert-the-time-input-to-local-time-zone-in-node-red-through-moment-function/58206)._
