# Create a diagram that can change the X-axis label
**URL:** <https://discourse.nodered.org/t/create-a-diagram-that-can-change-the-x-axis-label/88958>\
**Tags:** chart\
**Created:** [26 June 2024 05:22 UTC](https://discourse.nodered.org/t/create-a-diagram-that-can-change-the-x-axis-label/88958 "2024-06-26T05:22:23Z")\
**Post date:** [5 July 2024 07:12 UTC](https://discourse.nodered.org/t/create-a-diagram-that-can-change-the-x-axis-label/88958/4 "2024-07-05T07:12:00Z")
It is really hard to answer your question as you have not shown
the incoming data, how the data is display at current time, how you wish the data to be displayed and how your flow is configured.
All this should be in a form that is copyable and well formed.
[How to import/export a flow](https://nodered.org/docs/user-guide/editor/workspace/import-export)
There’s a great page in the docs ([Working with messages : Node-RED](https://nodered.org/docs/user-guide/messages)) that will explain how to use the debug panel to find the right path/value for any data item.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/create-a-diagram-that-can-change-the-x-axis-label/88958)._
