# Creating a Bounding Box
**URL:** <https://discourse.nodered.org/t/creating-a-bounding-box/88492>\
**Tags:** function-node\
**Created:** [4 June 2024 07:54 UTC](https://discourse.nodered.org/t/creating-a-bounding-box/88492 "2024-06-04T07:54:24Z")\
**Post date:** [5 June 2024 06:31 UTC](https://discourse.nodered.org/t/creating-a-bounding-box/88492/2 "2024-06-05T06:31:45Z")
> [@user1234](#):
> I tried using the palette node-red-contrib-post-object-detection but still met Failure \* ERR\_DLOPEN\_FAILED
Hi @user1234,
Did you follow all the installation [steps](https://discourse.nodered.org/t/object-detection-using-node-red-contrib-tfjs-coco-ssd/22931) of that node? That is required because it uses the [canvas](https://www.npmjs.com/package/canvas) npm package as a dependency for fast(er) drawing of the bounding boxes on the images.
Some other nodes (like e.g. node-red-contrib-object-detection) do it in pure javascript, so you don't need to do such extra build steps. But those use the [pureimage](https://www.npmjs.com/package/pureimage) npm package which is really slow and eats a lot of cpu. Which is not usable when you want to do a lot of image processing on hardware like e.g. a Raspberry Pi.
What is your use case? Do you need a lot of image processing?
Bart
_[View the full topic](https://discourse.nodered.org/t/creating-a-bounding-box/88492)._
