# Creating CRC16 xModem Hex Value
**URL:** <https://discourse.nodered.org/t/creating-crc16-xmodem-hex-value/81981>\
**Created:** [12 October 2023 19:33 UTC](https://discourse.nodered.org/t/creating-crc16-xmodem-hex-value/81981 "2023-10-12T19:33:33Z")\
**Post date:** [13 October 2023 07:44 UTC](https://discourse.nodered.org/t/creating-crc16-xmodem-hex-value/81981/2 "2023-10-13T07:44:02Z")
@michaelbusry welcome to the forum! First off it is JavaScript not Java they are two different things (grin)
Can you give some background info:
1. what version of Node-RED, and node.js are you running (see node-redstarxtup log)
2. what platform are you running NR on?
So you have something running so can you create a test flow demonstrating the problem. If you add a `debug` node to the output of what ever is sending you the json, you could put that in an `inject` node in the test flow. That way we can run your test flow to see what is happening.
````auto
   code goes here
_[View the full topic](https://discourse.nodered.org/t/creating-crc16-xmodem-hex-value/81981)._
