# Cron-plus: not showing entries in config?
**URL:** <https://discourse.nodered.org/t/cron-plus-not-showing-entries-in-config/16921>\
**Created:** [20 October 2019 12:42 UTC](https://discourse.nodered.org/t/cron-plus-not-showing-entries-in-config/16921 "2019-10-20T12:42:57Z")\
**Post date:** [20 October 2019 14:09 UTC](https://discourse.nodered.org/t/cron-plus-not-showing-entries-in-config/16921/4 "2019-10-20T14:09:58Z")
> [@TotallyInformation](#):
> Yes, you can use context storage and merge the incoming commands with your config data. Don't forget that everything in your node's js file outside the part that handles the incoming msg is active all of the time, so you can actually just define the variable there
Thanks for the Info. I'm not quite grasping this ATM (being thick myself). Do you have any demo code / sample or somewhere I can see this in action?
Here is my dashboard demo.
I left timezone out of it for now (defaults to system).
[Dynamic cron schedules / timers via dashboard control](https://flows.nodered.org/flow/79a66966a6cc655a827872a4af794b94)
_[View the full topic](https://discourse.nodered.org/t/cron-plus-not-showing-entries-in-config/16921)._
