# Custom node require failure
**URL:** <https://discourse.nodered.org/t/custom-node-require-failure/39772>\
**Created:** [26 January 2021 11:49 UTC](https://discourse.nodered.org/t/custom-node-require-failure/39772 "2021-01-26T11:49:00Z")\
**Post date:** [26 January 2021 12:06 UTC](https://discourse.nodered.org/t/custom-node-require-failure/39772/2 "2021-01-26T12:06:29Z")
Are the `require`d modules installed?
If you are able to step debug (e.g. in VScode) the put the keyword `debugger` before the require.
This might help...
> [@How to proper debug custom node](https://discourse.nodered.org/t/how-to-proper-debug-custom-node/9308/13):
> This is how I debug a custom node in VS Code... It works for me however since this is a dist version of node-red its difficult sometimes to debug client side issues. Other than that, debug stop points work in my node js files. For debuging my .html files, i enter debugger into the function & open F12 (chrome debugger stops on the debugger statement) Setup... Install node-red as per instructions on [nodered.org](http://nodered.org) Run it one time so that .node-red folder is generated Install own node... cd c:…
_[View the full topic](https://discourse.nodered.org/t/custom-node-require-failure/39772)._
